ZLX12P , Electro Voice monitor speaker schematic please
  • zen
    • 511
    Hi all
    This is my next repair project .
    There are a string of resistors connected in parallel that are visibly burnt . ( see picture )
    I suspect they are all 1R in value , but would like conformation before proceeding .
  • lotas
    • Jan 2016
    • 4617
    • Russia
    Re: ZLX12P , Electro Voice monitor speaker schematic please
    Yes, all resistors are 1 ohm
    • zen
      • 511
      Thanks very much Lotas
      • zen
        • 511
        Customer finally gave me the go ahead .
        Replaced all the 1R resistors mentioned
        Q1, ST Electronics 20N95K5 , S/C
        Also replaced control chip , Texas Instrument 3845B , with one i hope is the ST Electronics equivalent UC3845BD1.
        • zen
          • 511
          R26 ( 01A ) O/C
          Replace with a 100R .
          Can anyone confirm this is correct ? , as schematic showing as 150R , but assume that's a slightly different revision of the board .
          • lotas
            • Jan 2016
            • 4617
            • Russia
            R26-101- 100 Om
            • zen
              • 511
              Hi Lotas , thanks
              The 101 is the one i used to replace the original 01A .
              • lotas
                • Jan 2016
                • 4617
                • Russia
                01A - 101 = 100 Om, and about which one you wrote that it was at 150 Om.
                • zen
                  • 511
                  Ok , thanks .
                  Now working & on test .
                  • zen
                    • 511
                    Also removed cheap glue on board indiscriminately used over the electronics ,plus replaced the 2 yellow looking thermal pads on same heat sink as FET replaced , as they seemed to have started to break down , which potentially may have been the root cause of failure .
                    • Ali.kh
                      • Aug 2023
                      • Iran
                      hi , please post a photo of the input board ic3,4,5,6,7, unfortunately, the input signal has a problem, the op amps are burnt, if possible, send a pdf of the schematic of the input board, thank you
