complete newbie help please
  • stuartyp
    • Jun 2010
    • 6
    Hello can some you please help me i have no idea what im looking at but i would say that the cap is blowin
    can this cap be replaced be its self or is the whole lot going to have to be done
    as you can see there is quite a few of them its inside my phoenix gold power core its 20farad i have been told the whole thing is scrap many thanks stuarty
  • mockingbird
    • Dec 2008
    • 5484
    Re: complete newbie help please
    Wow!
    If I could guess I would say those are some low end Samxon variety.
    Send it to Topcat, it will keep him busy.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      replace all with mcz.
      • seanc
        • Nov 2008
        • 1319
        Looks like it's full of fakes to me.
        Rubbish sleeves, different vent styles.
        What does this device do?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          fakes!
          if they used fakes, i question the quality of everything else inside. may or may not be worth fixing.
          sigpic
          (Insert witty quote here)
          • AudioCraZ
            • Sep 2009
            • 147
            Wow... Look at the different vent caps... LOL
            You would figure that somebody making, or inspecting those would see a light bulb come on... Gotta love sub standard work.
            Post some pics of the rest of it, maybe somebody here can determine if it is worth salvaging or not.
            • kikkoman
              • Jul 2007
              • 691
              wait... am I the only one who sees a screw in that cap?
              "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                • 31111
                exactly, the screw is too long and has hit the cap.
                get a shorter screw.
                and then do a poly-mod!
                why not just use big beer-can size caps with a copper bus-bar?
                • stuartyp
                  • Jun 2010
                  • 6
                  I will put some more pictures up after work for you's. This is a 20farad power cap made be Phoenix gold for car audio.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOAAAAAAAAAAAAAAAAAAAHHHHHHHHHHHHHHH!
                    I've never seen so many caps on one device. That would take hours to re-cap. It looks like several are slightly bulging. I can't believe that the manufacturer would put one underneath a long screw, though!
                    • stuartyp
                      • Jun 2010
                      • 6
                      I must check the case tonight I don't think there is a screw near the caps. The lid screws on around the edges with 4/5 mm screws. Now I don't know what the last owner has done but when I opened it this is what I found. He told me that it works perfectly. I know it hasn't dropped any volts as it's stayed the same for the last 5/6 months but I have never conected anything to it yet. How can I test this
                      • stuartyp
                        • Jun 2010
                        • 6
                        I'm trying to get pictures of the outside of the cap to show there is no screws where the damage is done but can't find any on the net to copy I will do this when I get home
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          would be interesting what those caps are (label shots).
                          well.. more like what they're supposed to be after the sloppy resleeving job
                          cap values and quantity would be needed for an estimate to replace all those junk caps.
                          (+ you need to find someone willing to spend a couple hours on recapping )
                          • Scenic
                            o.O
                            • Sep 2007
                            • 2642
                            lol!
                            http://phoenixphorum.com/powercore-2...ight=powercore
                            looks like PG used to be a reputable high end brand (early stuff has only Pannys and NCCs), got bankrupt and switched owners 2 times.. resulting in garbage like this..
                            those are 288 caps in total btw
                            the other powercore model is even more scary.. with leaking, cracked aerogel supercaps...
                            http://phoenixphorum.com/15f-powercore-doa-vt10201.html
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              sounds like its a first class pile of shit.
                              how thick is the copper on the board?
                              i would just use an optima redtop or an oddesy agm in its place.
                              avoid kinetic.pure junk.
                              • seanc
                                • Nov 2008
                                • 1319
                                Having read the threads Scenic linked, I totally agree.
                                • stuartyp
                                  • Jun 2010
                                  • 6
                                  Yea i think i will give it a miss now. I have 3 stinger svp70 batterys this was just an extra that i was going to use for a distro block and to make sure there was no voltage drop when the car is being jugded for sq
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    your stingers are rebadged odessy's.
                                      • 31111
                                      what's wrong with a few "beer-can's" with copper busbar instead of a fuckload of tiny caps?
                                      most mobile-audio is a scam these days anyway - numbers quoted are always peak-music-power not rms.
                                      i used to put 300w amps in large cars and a pair of stage 12" drivers.
                                      it could rock the street & flex the body panels far more than a lot of the junk i see now.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        if you junk it, send it to c hegge- he would love to throw all 288 of those caps in the fire as firecrackers!
                                        not really- he lives down under... shipping could be a real b!tch...
                                        not that he wouldn't dream... he could make one hell of a Judah's belt out of all of those!
                                        sigpic
                                          HP ENVY Phoenix 860-122NF ENVY Phoenix 860 i5-6400 Specification for Upgrade or Repair
                                          This specification for the HP ENVY Phoenix 860-122NF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY Phoenix 860-122NF boardview and ENVY Phoenix 860-122NF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                          HP ENVY Phoenix 860-100nt ENVY Phoenix 860 i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP ENVY Phoenix 860-100nt can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY Phoenix 860-100nt boardview and ENVY Phoenix 860-100nt schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ENVY Phoenix 860-071kr ENVY Phoenix 860 i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP ENVY Phoenix 860-071kr can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY Phoenix 860-071kr boardview and ENVY Phoenix 860-071kr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ENVY Phoenix 850-011no ENVY Phoenix i5-4690K Specification for Upgrade or Repair
                                          This specification for the HP ENVY Phoenix 850-011no can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY Phoenix 850-011no boardview and ENVY Phoenix 850-011no schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP ENVY Phoenix 860-089cn ENVY Phoenix 860 i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP ENVY Phoenix 860-089cn can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ENVY Phoenix 860-089cn boardview and ENVY Phoenix 860-089cn schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
