DSP firmware error on a Pioneer LX86
  • ottobad
    • Aug 2016
    Please help me who went through the DSP firmware error on a Pioneer LX86.
    Mine now shows 1-204084 *** 160 .
    Every time I try to update the firmware via USB, the message Update Error 1 appears at 45%
    Thanks and sorry if I posted where I shouldn't .
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8243
    Re: DSP firmware error on a Pioneer LX86
    do a factory default / reset and try again updating...
    • mmartell
      • Oct 2013
      • 3189
      Replace the associated eeprom. It will likely need programming before installing so you'll have to search the net for the .bin file.
      • ottobad
        • Aug 2016
        Morning, thank you for reply. The DTS chip need to be replaced as well? I read on different forums and they said the eeprom is stored on DTS chips.
        I did a factory reset, I check what error appear in the service menu...the firmware is damadge.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8243
          Yeah, sounds like the eeprom is screwed.
          • Elektronek
            • Jul 2014
            • Poland
            Hi. Did you get Eeprom dump for those DSP?
            • dobrykamil
              • Jun 2013
              • 62
              Here is a working dump from LX56 which comes with the same dsp and spi chip.
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                Replaced emmc.
                Terminal log
                UART
                AC_ON
                E-B
                FDE enabled
                06-01-2025, 02:11 AM
              • EduCabral
                [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                by EduCabral
                I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                🔧 Details:
                • Model: YT-M06
                • Interface: Pioneer 1
                • MCU: Fujitsu MB89F202
                • Goal: Find a valid .bin firmware file or memory dump from a working unit
                I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                07-15-2025, 12:26 AM
              • medinfo
                Mac T2 after update(There was an error activating your device)
                by medinfo
                Macbook Pro 2019 T2
                iCloud OFF
                MDM unlocked by changing Serial Number
                worked fine but after latest update see (There was an error activating your device. Please try again).
                Erased and boot in internet recovery, same error.
                changed to original serial number (iCloud OFF & MDM ON), same error.
                tested with others serial number, same error.
                tested (CMD+R), (Option+CMD+R), (Shift+Option+CMD+R), same error
                Revived and restored by Apple Configurator and same error.
                Any help ?
                12-31-2023, 02:04 PM
              • TheUser
                Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                by TheUser
                Hello to everyone ,
                This is my first post here, and i would like to share with you a small story in case you can help me.
                Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                02-10-2024, 02:07 PM
              • ahmedtou
                HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                by ahmedtou
                help me please
                I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                I will share all the details with you, including the disc information.
                Code:
                HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                Current Profile: BD-R
                Disc Information:
                Status: Empty
                State of Last Session: Empty
                Erasable: No
                Free Sectors: 12,219,392
                Free Space: 25,025,314,816 bytes
                Free Time: 2715:27:17 (MM:SS:FF)
                Next
                08-27-2025, 08:49 AM
