Marantz 6009 no front display
  • frankusb
    • Apr 2015
    • 111
    I recently took this receiver out of storage and the front display shows no signs of life. Everything else is working fine. I have not worked with VFDs before so I am not sure how to approach debugging. Are there any good pointers to how VFDs work or typical failure modes?
    It seems that the NJM2887 should be Vo = Vref x (1 + R2 / R1). R1 is 100k, R2 is 225k, Vref is 1.29, so F+ should be 4.19DC (as marked).
    VH (the heater?) has 42VDC marked on the schematic.
    F- is GND.
  • R_J
    • 9569
    Re: Marantz 6009 no front display
    VH is not the heater, the heater (filament) on this display is F- and F+ check the voltage between the two pins. what is the voltage on F+ ? Check for poor solder connections and check C6118
    • frankusb
      • Apr 2015
      • 111
      F- to F+ measures 0.001. F+ to DGND measures 4.19VDC, F- to DGND measures 4.19VDC. C118 in circuit measures 12.6uF on a Fluke 12. R6083 to DGND measures 40.37.
      I reflowed the pins on FL601, they looked fine but I did them anyway.
      • budwich
        • Jul 2015
        • 3097
        check the resistance between +/- F
        • frankusb
          • Apr 2015
          • 111
          3.1 ohms in circuit.
          • R_J
            • 9569
            I suspect one or more of the D6005~D6007 diodes are open. check the voltage at each diode.
              • 31113
              the heater really should be AC
              • frankusb
                • Apr 2015
                • 111
                Unless I am mistaken, there are no AC sources connected.
                • frankusb
                  • Apr 2015
                  • 111
                  No power at the house at the moment (since 2am, winter storm) but diode test mode shows similar forward and reverse values for all 3. I will test voltages when we get power back.
                  • frankusb
                    • Apr 2015
                    • 111
                    Problem solved! I tried to get the measurements on the diodes and they looked reasonable and lo and behold the display was working. But after I power cycled, it was not. So i reflowed the diodes and C6118 and now the display is working.
                    I still don't have a firm grasp of how VFDs work but my receiver is back online so I thank all the people with suggestions.
                    • R_J
                      • 9569
                      Good to here it's working, here is one explanation, there are others on the internet https://www.noritake-elec.com/techno.../vfd-operation
                      • frankusb
                        • Apr 2015
                        • 111
                        Well, the display stopped working again. After some measuring, I found that D6007 appears to be conducting in both directions and the voltages are not proportional as I would expect.
                        4.19V, 1.06V and 0.54V.
                        What is the function of the diodes? If I am looking at the correct data sheet, it's a 1000V 1A rectifier. https://cdn.badcaps-static.com/pdfs/...a80cb05ad4.pdf. It's also marked obsolete.
                        Would this be an acceptable substitute?
                        https://www.mouser.com/ProductDetail...MdIHKbxA%3D%3D
                        • R_J
                          • 9569
                          Yes the diode is a 1A/1kv D6007, along with D6005 & DD6006 are in the return for the filament voltage of the display, but rather than connect direct to ground they lift it by 3 diode drops about 1.8 volts. I would replace all three diodes along with C6118.
                          • frankusb
                            • Apr 2015
                            • 111
                            Thanks R_J. Is the substitute I linked appropriate?
                            I am curious why they use a 1000V 1A diode. It's 4.2V and 163mA if the schematic is to be believed.
                            I will replace C6118 as well.
                            In use, 4.2V to 1.8V would be the voltage drop across the filament. NJM2887 is adjustable, why would one not just adjust it to 4.2-1.8 and skip the diodes?
                            • frankusb
                              • Apr 2015
                              • 111
                              Actually, https://www.mouser.com/ProductDetail...TF3Syt3w%3D%3D matches one more parameters.
                              • R_J
                                • 9569
                                The diodes provide a bias voltage to the display filament to prevent "ghost illumination"
                                They don't need to be 1kv but it is likely what they had in stock so they used them.
                                The model SR7005 uses three 1SR35-400 diodes (1A/400V)
                                • frankusb
                                  • Apr 2015
                                  • 111
                                  I replaced the diodes and capacitors today and the display is working again. The diodes measured 0.8V, 1.6V and 2.4V. Thank you for the help.
                                  Curiously the diodes and capacitor measure fine out of circuit.
                                  • acedogblast
                                    [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                    by acedogblast
                                    First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                    Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                    03-01-2023, 08:24 PM
                                  • Mark R
                                    Marantz Model 150 Tuner "NULL" Adjustment..
                                    by Mark R
                                    I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                                    Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                                    12-30-2024, 03:18 PM
                                  • BigOof
                                    Marantz SR5007 popping on volume change and mute in Direct Mode
                                    by BigOof
                                    I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                    12-12-2024, 06:15 AM
                                  • oshimapt
                                    marantz sr6012 no sound
                                    by oshimapt
                                    hello guys,
                                    first of all i'm not a qualified repair guy, i am a diy guy and as years pass by i have some experience on repairing eletronics, and i'm hoping someone can share their experience.
                                    i have a marantz sr6012, some times it turns on and works normal, but after a while the sound cuts off or it starts getting distorted and then cuts off.
                                    when this happens there is no audio no matter the source used, and the OSD shows unknow audio signal from the source.
                                    i was reading very carefuly the service manual and it is all pointing for...
                                    10-17-2024, 09:49 AM
                                  • acedogblast
                                    Marantz SR5012 popping and other sound issues
                                    by acedogblast
                                    Hello I have a Marantz SR5012 7.1 AV receiver that is producing speaker pop and other sound issues. These sounds are coming out of all connected speakers regardless if they are configured to be used. The rca preouts are clean from these defects so I am assuming the problem has to be with the amplifier.
                                    These sound issues are random and unpredictable. There are times where the unit can go 10 minutes without any problems then suddenly the problems come back. It doesn't seem to matter if there is sound being played or not.
                                    I have disassembled the unit and was able to take out the...
                                    02-15-2023, 01:40 PM
