Thorens TTA-2000 DC offset
  • zoldi211
    • Feb 2016
    • 26
    • Slovakia
    Hi, I bought Thorens TTA-2000, but I am affraid connect speakers because DC offset between the +/- terminal are 2,5V!!! This is normal value on this "A" class amplifier or is this faulty?
  • R_J
    • 9634
    Re: Thorens TTA-2000 DC offset
    Seems a bit high, does the amp have a DC offset adjustment inside? Are both channels the same?
    • petehall347
      • Jan 2015
      • 4451
      • United Kingdom
      looks like cap coupled output so will read some dc unloaded ..try a load on it ..
      • redwire
        • 3912
        zoldi, can you download the schematic from that forum and post here?
        Do both R, L channels have the same offset of 2.5V?
        • zoldi211
          • Feb 2016
          • 26
          • Slovakia
          Hi, schematic on german forum is incorrect. I found one in korean forum and this have only one error, R11 are before R12,R13. Some values are also incorrect, but there are only minimal differences. I measured input voltage: 71V, voltage after trimmer 53V. Voltage between R1 pins: 0,380mV. Heatsin after 30 min 60°C, but this is normal with this amplifier!
          • zoldi211
            • Feb 2016
            • 26
            • Slovakia
            Yes, both channels are same. DC adjustment maybe not...
            • petehall347
              • Jan 2015
              • 4451
              • United Kingdom
              if you haven't got a resistor to load the output use a crappy speaker .. that dc will go away .
              • zoldi211
                • Feb 2016
                • 26
                • Slovakia
                I haven't tried load on it, because I don't want to destroy the speakers...
                • petehall347
                  • Jan 2015
                  • 4451
                  • United Kingdom
                  its capacitor coupled output so unless the caps are leaking its normal to see some dc without speaker loads .
                  • zoldi211
                    • Feb 2016
                    • 26
                    • Slovakia
                    so do you think, i can use it normally with speakers?
                    • petehall347
                      • Jan 2015
                      • 4451
                      • United Kingdom
                      you should test it with speakers you don't care about first . or a suitable resistor .
                      • zoldi211
                        • Feb 2016
                        • 26
                        • Slovakia
                        OK, thanks. What type of resistor is suitable for this test (value in ohms, wattage)?
                        • petehall347
                          • Jan 2015
                          • 4451
                          • United Kingdom
                          8 or 16 ohms or around there or even higher ..there won't be any signal therefore little current as vol will be turned down . i guess anything over and including 1 watt should do it .. saying that i believe its class A so idle current will be high . just be quick . you just need to see it drop to 0v .
                          • R_J
                            • 9634
                            2.5vdc is not that much voltage, but you can place about a 1 amp fuse in series with your speaker just to be safe. Do not have a source connected and playing music etc. as that would blow the fuse for sure. just use this setup to check the dc offset
                            • petehall347
                              • Jan 2015
                              • 4451
                              • United Kingdom
                              one thing it isnt dc offset on this amp .. its called dc balance .. one output is at rail and the other about half that . that's why it has a capacitor to block the dc ..
                              • redwire
                                • 3912
                                As others have mentioned, this amplifier is not DC-coupled to the loudspeaker. It uses a large coupling capacitor C1 10,000uF
                                So your DCV reading is likely due to small leakage currents in the big cap. In pictures this amp has a speaker protector relay board? Does it have one?
                                I did blow up an amp Dynaco ST-120 which also uses huge output-coupling caps. You have to be careful.
                                When you switch it off, the cap is still charged for a long time, and I was changing speaker wires and shorted them or something heard a thump and it blew the amplifier- even though it was turned OFF.
                                • R_J
                                  • 9634
                                  Now that I look closer at the schematic in post 5 I see the output cap. so I guess there is no _____ adjustment.
                                  I don't think the stock unit has speaker protection.
                                  https://old-fidelity-forum.de/thread-41267.html
                                  RIP Meatloaf
                                  • petehall347
                                    • Jan 2015
                                    • 4451
                                    • United Kingdom
                                    adjustment for dc balance is done with a scope and set for equal clipping .
                                    one note is when adjusting the idle current can change the dc balance and visa versa vi best to have 2 meters hooked up along with the scope and sine wave input then sort of trade off idle current and dc balance till its right .
                                    • redwire
                                      • 3912
                                      I think you need a speaker relay to stop the huge thump until the output caps charge up. Not for (shorted output transistor) protection.
                                      There are pics of TTA-2000 with and without one. It might be a mod or add-on. The old Dynaco ST-120 used to make a loud thump with woofer cone lurching out on power up, and slowly sinking back in until output cap charged up.
                                      I don't know what the trimpots are for.
                                      RIP Bat Out of hell, among my first rock LP's bought.
                                      • zoldi211
                                        • Feb 2016
                                        • 26
                                        • Slovakia
                                        The test is done. With old speakers and 1A fuse, because I dont have suitable resistor. After turning on, the current disappeared. I measured only 0,04 or 0 mA.
                                        A have a version with protection board with relay (1. photo in post #19).
                                        • dicky96
                                          What 'class' is this Hill Audio DX3000 Amplifier?
                                          by dicky96
                                          Hi guys, this is general query really
                                          So I have a Hill DX3000 3KW audio amplifier here.
                                          It has a topology/design like a class A/B but all the banks of output transistors (10 transistors in each 'side' of the channel) are NPN.
                                          I was wondering what class this is. It doesn't fit the description of class A.
                                          It also doesn't match class A/B or B amplifiers as all the examples I see have a complimentary output stage desigs (NPN/PNP) and clearly is not G, H or D
                                          I looked for 'class A push pull' but that didn't tell me anything either
                                          05-04-2022, 04:20 AM
                                        • madan1
                                          DALI SUB E-12F class D, fluctuating power rail
                                          by madan1
                                          Good day everyone.
                                          I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                                          The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                                          The normal value of the positive and negative power rails is +/- 43V.
                                          The positive rail stays...
                                          10-15-2025, 10:33 AM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
                                        • jinu_j
                                          How to test Subwoofer Amplifier with only a multimeter
                                          by jinu_j
                                          Hi Folks
                                          Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                                          Problem
                                          I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                                          Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                                          Any advice would be appreciated...
                                          08-29-2024, 02:05 AM
