Sony STR-DE845 setting reset and demo mode after power loss
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Just as described, when I lose power, it resets all settings and goes into demo mode (easily back to normal turning off when the demo message appears and turning back on). But it does it every time it loses power
  • R_J
    • Jun 2012
    • 9568
    Re: Sony STR-DE845 setting reset and demo mode after power loss
    Replace C105 on the display board, 0.22F 5.5v This supercap is likely used to maintain the settings.
    • odie34
      Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
      by odie34
      I am a hobbyist (not a professional) so please be gentle...
      I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
      I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
      02-18-2024, 09:11 AM
    • Carlos#2003%
      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
      by Carlos#2003%
      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
      02-15-2024, 07:52 PM
    • thstuff
      Sony OLED XR-77A80J - Initially dead, now 4 Flashes
      by thstuff
      A) TV initially dead
      B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
      C) Was able to perform a Reset from Settings menu and completed out of box configuration.
      D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
      E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
      12-26-2024, 09:10 PM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
      Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
      This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-06-2024, 05:27 AM
