Hi guys, I'm working on an Integra DTR-80.1 receiver, with complaint of smoke, and some channels not working. Upon inspection, I immediately noticed some exploded/bulged caps on what looks to be the preamp stage(?) 5 out of the 9 channels have the same bad cap (C6026, C6021, C6022, C6023, C6025), also, those bad channels, also each had a resistor way out of spec (R6286, R6281, R6282, R6283, R6285). Fuses F6603 and F6604 are blown. Is there anything else I should check before I throw fuses at it, and function check? Also, do these channels pop out with just one screw at the bottom? It would be so much easier to replace and inspect components with the board out. Any help would be much appreciated. Thanks!
Onkyo DTR-80.1
Re: Onkyo DTR-80.1
I'm 100% sure that you have a bunch of other components that are bad. I would go over at each channel, and test all the components.
I would test those final transistors on the big heat sink as well.
I have never heard something like this, where so many channels are blown at once. -
Re: Onkyo DTR-80.1
Okay, so you are correct. 6 out of the 9 output transistors are toast. Do you think this thing is worth fixing at this point?I'm 100% sure that you have a bunch of other components that are bad. I would go over at each channel, and test all the components.
I have never heard something like this, where so many channels are blown at once.Comment
Re: Onkyo DTR-80.1
Can the idle bias be checked on a dead circuit? I also found 6 out of the 9 output transistors to be toast. Do you think this thing is worth fixing? I think it was a $3000 amp back in the day. If you care to look at the manual, the output stages are on page 10 and 11.
https://manualmachine.com/integra/dt...ervice-manual/Comment
Re: Onkyo DTR-80.1
up to you if you want to fix it. schematic there that's available without registering is crap, and I'm sure not going to register/pay for a copy.
you can try to adjust it if instructions are in there, but probably need to have those burned parts replaced and somehow set the idle current to minimum and increase until it hits the recommended current. Make sure the 82 ohm resistor (R6071 and whatever it is on the other duplicate boards) are also intact.Comment
Re: Onkyo DTR-80.1
I'm pretty sure there are still a lot of burned/bad parts in there.
If you have the patience to go through each component, on each of those channels, then yes you could fix it. You will have to take it apart completely, to be able to measure all the components at those bad channels, even the main bottom board as well.
Usually, I measure all the components when I start, I make a list what is needed, I buy them, replace them and measure again all the components all over again, just to be sure.Comment
Re: Onkyo DTR-80.1
I only checked the PNP's on top. The mates are way down in there. I'm still trying to figure out how to get the preamp boards out, so I can access the lower ones. It looks like I might have to take the whole thing apart. If the idle bias is out of spec on one channel, can that cause other channels to fail? I'm kind of a noob. Thanks for you patients and understanding.Comment
Re: Onkyo DTR-80.1
Usually one channel does not cause others to fail; been trying to poll what causes these failures, as far as I can tell it's abuse like accidental output shorts and/or turning volume up way too high. Did you ask how it failed, what happened just before? These don't usually spontaneously fail as far as I can tell, but shorting outputs can be quite detrimental.Comment
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
by Tom_xHi friends!
I'm looking for schematic diagram for Onkyo grand integra A-G10 (A-8890)
speaker relays not activated, maybe protection circuit blocking.
If i power on for a minute, and power off and on again, speaker relays activated and unit working.
thx
Tom-
12-02-2023, 01:30 PM -
by RolinI have an Integra DBS-50.2 Blu-Ray Player that I haven't used in a while. Tried to turn on and it turned on for a brief moment with "hello" on the display then shuts off. Dead from that point on unless I unplug it and try again. Took it apart and checked a few well labeled voltages on the Power Supply board and found the 3.3V isn't measuring on the board (unless I'm misunderstanding what I'm measuring). I have a few pics of the board and schematics. There's a 4 PIN voltage regulator at location IC1301 with a part number 070XFC1 by Sharp that I believe should output 3.3V on PIN2,...
by Sik_6ty_SixxSo like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...5 Photos
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... - Loading...
