Looking for a Service Manual for Traktor Kontrol S4 MK1
  • Jolly62
    • Nov 2021
    • 13
    • Italy
    I got a NATIVE INSTRUMENTS Traktor Kontrol S4 MK1 with the common issue of a broken USB Type B port. After I replaced it the controller can't be recognized by the PC: I tried with several Windows and Mac PCs with the latest S4 drivers.
    All the correct voltage values are present so I suspect the issue could be the USB controller IC: CY7C68013A-100AXC with a 24LC64 eeprom.
    I looked around for the service manual with no luck so I wonder if someone could be so nice to share it.
    Thanks!
    • 30906
    Re: Looking for a Service Manual
    CY7C68013A has no internal code,
    it will connect to usb using a VID & PID from a valid eeprom, or use a default one from itself.
    so if you check the device manager you should see it connect even if the driver is missing.
    if it connects then it may be a corrupt eeprom - although i cant see why.
    i suspect you have shorted d+ and d- or a brocken filter.
    • Jolly62
      • Nov 2021
      • 13
      • Italy
      Yep, it uses the separate 24LC64 eeprom.
      D+ and D- are not shorted according my meter and they are connected directly to the USB port.
      There are two fuses on the USB ground and +5v lines and they are good.
      Windows 7 gives "USB Device Not Recognized" with or without the S4 drivers.
      What filter should I check?
        • 30906
        if you go into the hardware, does it show a device and it's VID & PID numbers?
        • Jolly62
          • Nov 2021
          • 13
          • Italy
          No, in the attached pic you can see what I got.
          I have access to a digital scope (Siglent 1202X-E) if this could help.
          • Jolly62
            • Nov 2021
            • 13
            • Italy
            Re: Looking for a Service Manual for Traktor Kontrol S4 MK1
            I found the attached guide so I checked the CLKOUT pin with a scope: I see a good signal for just a second then it reduces its amplitude a lot but I can still get the frequency that is the same as the crystal, 24 Mhz.
            From the guide I can read "Suspend mode happens if the FX2LP is not seeing the regular start of frame (SOF) bus signals from the host and WAKEUP# is high."
            I checked the WAKEUP pin and I see 2,89 V.
            • Jolly62
              • Nov 2021
              • 13
              • Italy
              Just for the record, I got a new CY7C68013A from China and, after a not so easy replacement job, now the Traktor Kontrol S4 MK1 is working again.
              • gtech83
                • Dec 2010
                Any schematics of PCB1 or service manual discovered? troubleshooting a short after someones horrible usb repair, will chuck more hours at this
                  • 30906
                  you can get a datasheet from cypress for the main chip - that shows the usb wiring
                  • afminguela
                    • May 2023
                    • spain
                    hi, if some one found the service manual please4 post. tnx
                    • kooroshi60
                      Traktor Kontrol S4 MK1 Flash dump
                      by kooroshi60
                      Hi guys
                      I need the Flash Dump (.bin) file of the Traktor Kontrol S4 MK1. SPI chip number is 25DF041A from Atmel (4Mbit)
                      So please let me know if you have the .BIN Dump of this model and its price and the payment method.
                      I appreciate your help.
                      10-01-2024, 10:17 AM
                    • afminguela
                      No signal right output master channel - TRAKTOR KONTROL S4 MK1
                      by afminguela
                      HI,
                      i have a S4 MK1 and suddenly don't have signal at the right channel main output, both in rcd and trs outputs.
                      One day I was plugging all the set ( Macbook air+ traktor kontrol) and when I play the first song, right channel was silent.
                      i made all the silly checklist (SW mapping, connectors, swapping channels...etc)
                      and I concluded that is a hardware issue.
                      As both physical outputs are affected, I suppose it's something at the mainboard BEFORE the split. No item seems to be burned, or broken, at sightsee.
                      Does...
                      05-11-2023, 05:58 AM
                      Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                      Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                      various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                      Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                      trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                      what is wrong with your PC in just seconds. It saves you time and money.
                      Our new and improved design...
                      11-01-2024, 06:29 AM
                    • spantor
                      power board manual philips 55pus6482/12 715g-p01-000-0h2s
                      by spantor
                      Hello.
                      Some components have exploded and I can't figure out the values. I have obtained the manual for this power supply for 65" but comparing components there are some differences and it is not reliable.
                      Could someone leave me the power supply manual for this 55" model?
                      I would be very grateful
                      03-19-2024, 01:19 PM
                    • H34TO
                      ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                      by H34TO
                      Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                      06-17-2025, 07:17 AM
