Looking for a Service Manual for Traktor Kontrol S4 MK1
    I got a NATIVE INSTRUMENTS Traktor Kontrol S4 MK1 with the common issue of a broken USB Type B port. After I replaced it the controller can't be recognized by the PC: I tried with several Windows and Mac PCs with the latest S4 drivers.
    All the correct voltage values are present so I suspect the issue could be the USB controller IC: CY7C68013A-100AXC with a 24LC64 eeprom.
    I looked around for the service manual with no luck so I wonder if someone could be so nice to share it.
    Thanks!
    Re: Looking for a Service Manual
    CY7C68013A has no internal code,
    it will connect to usb using a VID & PID from a valid eeprom, or use a default one from itself.
    so if you check the device manager you should see it connect even if the driver is missing.
    if it connects then it may be a corrupt eeprom - although i cant see why.
    i suspect you have shorted d+ and d- or a brocken filter.
      Yep, it uses the separate 24LC64 eeprom.
      D+ and D- are not shorted according my meter and they are connected directly to the USB port.
      There are two fuses on the USB ground and +5v lines and they are good.
      Windows 7 gives "USB Device Not Recognized" with or without the S4 drivers.
      What filter should I check?
        if you go into the hardware, does it show a device and it's VID & PID numbers?
          No, in the attached pic you can see what I got.
          I have access to a digital scope (Siglent 1202X-E) if this could help.
            Re: Looking for a Service Manual for Traktor Kontrol S4 MK1
            I found the attached guide so I checked the CLKOUT pin with a scope: I see a good signal for just a second then it reduces its amplitude a lot but I can still get the frequency that is the same as the crystal, 24 Mhz.
            From the guide I can read "Suspend mode happens if the FX2LP is not seeing the regular start of frame (SOF) bus signals from the host and WAKEUP# is high."
            I checked the WAKEUP pin and I see 2,89 V.
              Just for the record, I got a new CY7C68013A from China and, after a not so easy replacement job, now the Traktor Kontrol S4 MK1 is working again.
                Any schematics of PCB1 or service manual discovered? troubleshooting a short after someones horrible usb repair, will chuck more hours at this
                  you can get a datasheet from cypress for the main chip - that shows the usb wiring
                    hi, if some one found the service manual please4 post. tnx
