Yamaha RX A3020
  • Andrealikescaps
    • Dec 2013
    • 17
    Yamaha RX A3020
    Hello friendly Badcaps community.
    I have one of these on my desk today, and I have attached a service manual if it is beneficial to anyone.
    It turns on OK but no audio output to speakers unless the 'pure direct' button is pressed, and even then after 30 seconds, audio stops.
    There is no relay click when the sound stops, so not a relay control problem.
    Headphone audio stops when speaker audio stops, so not likely a power amp problem.
    It does not appear to be in any protection mode.
    Factory reset has made no change.
    After the first attempt to get sound, the problem takes less time to occur (5 sec), so temperature seems to be relevant.
    Allowing a cool off time (placing in standby), returns 30 sec of audio function again.
    Using headphone output to monitor audio instead of speakers does not change behaviour either.
    So it appears something is getting hot and inhibiting audio.
    FLIR imaging shows Q1810 and Q1809 getting hot, however I'm not sure if this is relevant.
    I've been burned before by going after hot components that are normally running hot, pun intended. So I'm asking if anyone else has come across this sort of behaviour in these devices and if the problem was indeed found within the 'AMPPOWER (1) board or elsewhere?
    Many thanks in advance for your shared wisdom.
  • victorcas
    • Oct 2021
    • 12
    • España
    Re: Yamaha RX A3020
    I have found some devices with a similar error that was due to dirt (mostly sticky liquids) that when heated, increased the conductivity in some areas.
    This might not be your case, but I don't know what else it could be.
    Maybe there is a temperature sensor that makes it go into protection mode, although it is rare because otherwise it would generate an error or disconnect the relays. Just to try, you could try to heat the sensor to see if it disconnects earlier.
    In order to discover where is the conflictive zone located, you can try to heat up some small areas while testing....
    • Andrealikescaps
      • Dec 2013
      • 17
      Re: Yamaha RX A3020
      Thanks Victorcas, no sign of liquid spills, but just in case I sprayed out the boards with IPA and compressed air.
      Removed quite a bit of dust but unfortunately the problem remained unchanged until....
      The circuit shows Q1810 and Q1809 conduct the entire +-60V supply to the amplifiers.
      So they are likely to run hot anyway, so I'm putting that down as a red herring.
      For the sheer pleasure of it, i went through the Idling current adjustments.
      Once this was complete and all the channels were within the 15+-2mV spec and <100mV DC at the speakers, reconnecting the speakers gave reliable full output, even without the 'pure direct' button engaged !!!
      So I thought that was it? but no, after about 5 minutes the problem returned.......
      Checked idle current adjustments, all still within spec....
      Let it cool and OK again but only on pure direct.
      I did notice that when I had output on all channels, I had engaged the 'straight' button which seems to direct stereo input to all channels. A bunch of 'icons' on the display lit up when this was working well, but these indications are now absent from the display.
      Quite peculiar....
      Anyone had any similar woes with these heavy devices?
      • mmartell
        • Oct 2013
        • 3189
        Re: Yamaha RX A3020
        Having a similar issue with a Marantz. Any BGA devices in the audio chain on that board by any chance ?
        • Andrealikescaps
          • Dec 2013
          • 17
          Re: Yamaha RX A3020
          No BGA's fortunately.
          • budwich
            • Jul 2015
            • 3097
            Re: Yamaha RX A3020
            what inputs have you tested with? What kind of signal input do you have access to? Do you have a scope to look for signals along path? Did you check at the pre-outs? A picture of the display when powered up might help. Any difference when the tuner is selected?
            • victorcas
              • Oct 2021
              • 12
              • España
              Re: Yamaha RX A3020
              Does it behave the same if you connect more load to the output? (or increasing the volume) I say this in case the problem could be due to the power stage or the audio processing area.
              If you connect it with the audio very low and the same thing happens at the same time, I guess the problem would not be the power stage.
              If its the audio processing area, and there is not a BGA IC, it could be an LGA IC. Maybe you could try applying heat to some of these chips to see if the error occurs.
              • SlimMoses
                • Dec 2021
                • Sweden
                Re: Yamaha RX A3020
                Had the same problem with my RX-A2010 and have now solved it.
                Running Self Diagnostic Test C2.1 which test bus communication to DSP2 on digital2 PCB on the receiver didn't get anything, neither ok or faulty. Couldn't even check the firmware version. So with that test it seemed the problem lay within the DSP2 chipset on the Digital 2 P.C.B.
                Checked the possibility to order a new Digital 2 P.C.B. and they are still available for around €100.
                I thought I'll first will try to bake the PCB in the oven before I order a replacement.
                Placed it on a piece of wood in the oven on 200°C (392°F) for 15 minutes with the DSP2-chip facing down and resting straight with help of the board power socket, chassi mounting and the cable tie that is mounted on the board. I let it cool down and then mounted it again and now it works perfectly and the self diagnostic test are all ok regarding firmware version, checksum and the bus signal to the DSP2.
                Saved me €100
                • Thieu75
                  • Dec 2021
                  • France
                  Re: Yamaha RX A3020
                  Saved me €100
                  Just in case where did you find the Digital 2 PCB?
                  • Andrealikescaps
                    • Dec 2013
                    • 17
                    Re: Yamaha RX A3020
                    Thank you for your questions.
                    I'm testing with the tuner input.
                    I have access to a function generator.
                    I have a scope.
                    Not checked pre-outs.
                    Display output is normal, no errors, not in fault mode.
                    • Andrealikescaps
                      • Dec 2013
                      • 17
                      Re: Yamaha RX A3020
                      C2.1 on this one is network check. Shows all ok so long as you connect it to a network switch.
                      C1.7 however is more interesting as it shows NG.
                      BUS DSP1 is reporting an error then.
                      IC911 on the DIGITAL (1) board.
                      Will take a look around there.
                      • Andrealikescaps
                        • Dec 2013
                        • 17
                        Re: Yamaha RX A3020
                        Fascinating.
                        At 50 degrees C, DSP1 (IC911) is happy, everything works,
                        at 45 degrees C, it stops.
                        Regular and repeatable.
                        Using a thermostatically controlled heat gun, I baked the chip at 150 degrees C for 15 minutes.
                        So far the bakeout appears to have been successful and all channels are running again.
                        Thanks SlimMoses !
                        • SlimMoses
                          • Dec 2021
                          • Sweden
                          Re: Yamaha RX A3020
                          Originally posted by Andrealikescaps
                          Fascinating.
                          Thanks SlimMoses !
                          I'm happy it worked for you too!
                          • skykomish@hotmail.com
                            • Jan 2025
                            Hi
                            im hoping you can help as you’ve worked in this receiver. I have one I picked up second hand. Had been working fine until I was playing vinyl and decided to change my cartridge with the receiver still on and record player still powered on. As soon as I removed the headshell and cartridge the receiver died. There is a click when I plug in the power cord but no action when hitting the power button. Seems a relay makes a sound when I first plug in the power cord but nothing after that. I’m hoping it’s the infamous Yamaha green cap and was wondering if you know what capacitor value I should use to replace the power supply capacitor in the Yamaha rx a3020, thank you in advance
                            • jjne
                              Yamaha RX V675 sound issues
                              by jjne
                              I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                              From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                              At first I thought it was either a speaker relay or the DSP, but I don't think...
                              06-24-2025, 07:01 AM
                            • sanalelevenstar
                              Yamaha RX-V485 Wn9711 Update
                              by sanalelevenstar
                              Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
                              I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
                              I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
                              12-04-2024, 04:32 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • Federause
                              HP 250 G7 - Battery Issue (Lid behaviour)
                              by Federause
                              I have an HP 250 G7 for assistance. I've changed the battery (the old was dead) with a not-original.
                              It has a particular behaviour that I've never seen:
                              With the lid open, the voltage is present on the relative pins. Upon a time I close the lid, after 5-10 sec. the voltage drops down to 0. If I re-open the lid, the battery keeps stuck in this situation. I have to connect the power supply to "resurrect" the battery. In this way, I can power on the laptop without any problem and also use it without the power cord. If i shutdown the laptop, keeps it with the...
                              09-08-2024, 03:34 AM
                            • sanalelevenstar
                              Yamaha RX-V485 receiver. After encountering a "version error"
                              by sanalelevenstar
                              I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
                              After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
                              I managed to find the service...
                              09-10-2025, 01:54 AM
