this amp board keep burning t1p4c1 transistor any help would be great think the resistor and the input section may be the problem not correct rating
power speaker board AMP008-1
Re: power speaker board
That TIP41C got mighty toasty. Catastrophic failure usually is caused by catastrophic issues... do you know what happened before it started frying these? This is not the first transistor it fried?
Who made the amplifier? What model is it, perhaps someone can find the schematic.
Else please show a good photo of the tracks on the other side of the board. -
reason why I ask is something seems very wrong with the circuit.
Yes the TIP41 is paired with the TIP42 but I would imagine audio amplifiers should be stereo these days and this is not paired with another channel so I don't know what it's doing. Is this a 2.1 amplifier perhaps, still odd the high power transistors are paired and these mere TIP41/TIP42 is not if they go to the LFE.
Also resistors usually do not go short when they fail.Comment
what is the full history of this thing from when it worked up until now ? to me anything could have happened from a lightning strike to anyone's guessComment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... - Loading...
