Marantz SR7011 No Audio DSP Issue
  • mmartell
    • Oct 2013
    • 3189
    HDMI video works perfectly as does the GUI. No sound from tuner, internet tuner or HDMI have not yet tried analog inputs. No audio from Direct or Pure Direct mode either.
    If I go to Setup/General/Information/Firmware I have a numeric value for Version but beneath that the entry for -DTS Version has all zero's.
    If I go into Version Display Mode by holding Status and Dimmer while powering on (page 133 SM) I get FIRM ERR but after that everything appears good except #4 DSP 1/2/3/4 ROM: those are all zero's as well.
    Seems the DSP's are not functioning how can I use the SM to locate the source of the problem ?
    Service Manual attached.
  • BigOof
    Marantz SR5007 popping on volume change and mute in Direct Mode
    by BigOof
    I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
    12-12-2024, 06:15 AM
  • benspawn02
    Anthem MRX500 - no sound. R2A15218FP issue??
    by benspawn02
    Dear Electronics Experts:
    I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
    08-12-2023, 04:46 AM
  • Mark R
    Marantz Model 150 Tuner "NULL" Adjustment..
    by Mark R
    I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
    Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
    12-30-2024, 03:18 PM
  • Mark R
    Marantz Model 120 Tuner Craziness I am Stumped!
    by Mark R
    My Marantz 120 Tuner stopped receiving Stereo signals. It works fine other then Stereo. I have a fully loaded shop here with all test equipment except and RF signal Generator.
    I get great reception on FM so I have used that signal troubleshoot. I have been all over the MPX board and replaced all caps. Also the entire power supply caps were replaced.
    All Voltages on the MPX board are good... all Transistors Good...All Diodes Good and other components.
    The stereo lamp is good as I powered it up and it lights. The signal flow to that lamp is unbelievably...
    10-20-2023, 01:25 PM
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
