do these look fake transistors to you ?
  • petehall347
    • Jan 2015
    • 4423
    • United Kingdom
    https://www.ebay.co.uk/itm/172486863212
    just got these tip41c tip42c from that ebay as rs dont have then right now .. they worked pretty good for a few seconds . one pair blew up with sparks and smoke and a bit of a bang then i disconnect them and turned the amp back on and the other pair blew up . all shorted across bce .
  • diif
    • Feb 2014
    • 6978
    • England
    Re: do these look fake transistors to you ?
    The same seller is selling fake Wago connectors as Waco, so a good chance they are fake.
    • petehall347
      • Jan 2015
      • 4423
      • United Kingdom
      best not try the others then .. not like i was going to .. have too much on without having to repair the damage they done .. 2 burned collector tracks to name the obvious . one driver is reading oddly on diode test but was from that ebay so no idea if thats fake too . https://www.ebay.co.uk/itm/232553805102
      they do play low level music seeming ok so might be good ..
      • petehall347
        • Jan 2015
        • 4423
        • United Kingdom
        well i just sent pics to seller and included this comparison to a known genuine fairchild tip32c ...
        • petehall347
          • Jan 2015
          • 4423
          • United Kingdom
          just had a refund so no massive loss .just my time ..
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8670
            Wow LOL, yeah that logo looks wrong.
            Sigh so even BJTs have fakes...how many amps were you pumping through it before they blew, or it was just voltage?
            Was looking at this MJE105 I have in my parts box, wonder if I should fleabay it and buy cheaper TIP42s... I guess not...
            • petehall347
              • Jan 2015
              • 4423
              • United Kingdom
              unsure of the current .i just turned the volume up some . maybe 10 or 20 watts worth and then fireworks
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8670
                horrible indeed I^2*R - probably only an amp or so for an 8 ohm speaker. Probably a 2N4401 in a TIP42 case?!
                • petehall347
                  • Jan 2015
                  • 4423
                  • United Kingdom
                  no idea whats inside them ..i know they aren't what they say they are .
                  • karatzdi
                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                    by karatzdi
                    I know some might say... just buy another one. Sell it as parts..!
                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                    Spent some time downloading the Service...
                    06-11-2024, 08:38 AM
                  • Francesc V.
                    Onkyo A8200 - Not the right voltages in some transistors
                    by Francesc V.
                    Hi:
                    I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
                    With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
                    Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
                    Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
                    I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
                    04-19-2025, 07:17 AM
                  • redbaron1007
                    Sundown SFB-8000D What are these transistors?
                    by redbaron1007
                    I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
                    My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
                    11-12-2023, 07:30 PM
                  • Bob Wong
                    MSI Crosshair 15 A11UEK. Need help with Transistors!!!
                    by Bob Wong
                    Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
                    In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
                    P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
                    03-15-2025, 02:02 PM
                  • paparazzo79
                    Fake magsafe 2 charger
                    by paparazzo79
                    Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
                    I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
                    what to do?Should I use the fake one?
                    Will it damage the macbook?...
                    10-02-2024, 08:18 AM
