Revenge lil Rock 5 repair
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8184
    Got a Revenge lil Rock 5 in for repair. It seems to be some sort of a small guitar tube amp.
    Complaint: Doesn't work.
    Fix: R13 390 Ohm 5W resistor open. Replaced it with a 7W 390 Ohm resistor, working A1.
    Didn't find any schematic online, so I scanned the paper I had.
    • 31051
    Re: Revenge lil Rock 5 repair
    lol
    when a saw the name i thought it was a graphics card!
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8184
      Well... hate to disappoint, but it's just a little tiny guitar tube amp. It's nothing really special and was a easy repair. I couldn't find any schematic for it online. Luckily the owner had a print out schematic, so I uploaded it.
      However... stay tuned... I've got a repair on an interesting device coming up. A road surface friction tester that has problems. No schematics for it (yet). I just came out of surgery yesterday, so it will be a bit until I'll get that on my bench. For now I am just taking it easy.
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        by mikey5791
        Hi to all forum members,
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • chth96
        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
        by chth96
        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
        Since then, This AC/DC adaptor have been out of order.
        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
        And Is there any possibility that it will suddenly explode as well as to be out...
        12-03-2023, 04:40 AM
