LG NB4530A soundbar abruptly powering off
  • dlxmax
    • Jul 2021
    • South Korea
    I've had my LG NB4530A soundbar for 7 years.
    It's been great up until the past few days.
    After playing sound for about 30 minutes it now shuts off abruptly.
    There's no "GOODBYE" message on the LCD, and the standby light doesn't illuminate.
    However, I can turn it right back on, but it will only stay on for minutes (or less) before dying again.
    I'm looking at the service manual (attached) and there isn't a section addressing this kind of issue.
    I do have a multimeter, and a rework station, but no oscilloscope.
    I've already removed the mainboard for testing. I just don't know where to start looking.
    Where would you begin testing?
    Thanks for your ideas!
    I strive to prevent e-waste as much as possible!
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG NB4530A soundbar abruptly powering off
    After 7 years, any electrolytic capacitors, also check for possible dry joints.
    • dlxmax
      • Jul 2021
      • South Korea
      I checked some of the caps in the hottest area and they measured within spec, and I didn't spot any dry joints. I reached out to LG here in Korea about getting a replacement mainboard and they wouldn't sell me one, but they apparently still service this model so I set about putting it back together. And now it works just fine.
      Since it was exhibiting the problem on my test bench before disassembly, possibly one of the ribbon cables or plugs needed reseating. Or maybe the gremlins departed when the case was opened? lol
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Reminds me of the free 42" LG plasma I got from a shop. Apparently it would shut down after a few minutes. All I did was take the back off and blow the dead roaches off the sustain boards. Plugged it in and it never turned off by itself since.
        A working TV? How boring!
        • madan1
          • Nov 2016
          • 682
          Is there a heatsink on TAS5612LADDVR / ic701? If yes, change the thermal paste.
          • valvashon
            LG 55UH6150- trouble powering up, then half lit screen (pictures!)
            by valvashon
            The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
            Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
            11-24-2024, 12:08 PM
            I found this video when looking for something else but this is how to use a phone charger for testing LED light bulbs
            Here is the website link for this project that I plan on making
            https://www.youtube.com/watch?v=atLERDZx0Q8
            But I going to use a different enclosure for this project and make it more professional looking and use safety features that was not used in this video
            I have some 24 volt switching power supply from my battery testing machine that I modified for a different switching power supply that is more suited for my new application and new purpose for testing BMS protection boards
            If can find one that I can modify the voltage output on I have a...
            09-09-2024, 04:47 AM
            Some New Preliminary testing of 21700 Tool battery cells to 2.00
            I decided to try a new approach to testing unbalanced battery cells with my battery testing machine that has more graph curve information and it looks like if you discharge them to 2.00 volts if the battery voltage does not come back to over 3.something volts you have some kind of issue with that battery cell
            I going to do more testing and see if is the case or not
            More to come later
            05-04-2023, 05:11 AM
            I just bought a SkyRc MC3000 battery testing machine very interesting device temp
            I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
            The charger has four individual temperature sensors for each battery cell
            The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
            Or test...
            09-14-2022, 07:12 PM
          • DarKHawK
            Asus 2021 ROG Strix G17 G713 not powering on and not charging.
            by DarKHawK
            I have an Asus 2021 ROG Strix G17 G713 that is not powering on and not charging. Board number is G533-6050A3250201.
            When plugged in, I found that the 3.3v/5v regulator was getting extremely hot, so I removed, next I found a short on the 3.3V rail. Removed the two 3.3v mosfets and found one of them shorted, but still the short on the rail did not clear. Then I injected voltage at that rail, and found out that U60400 the 2.5v rail was also getting hot. Removing it changed the short from 0 ohms to about 5-6 ohms, then I remove a bunch of other suspect components but that did...
            07-11-2025, 05:24 AM
