Pioneer VSX-922 UPC error
  • bermo96
    • Jan 2019
    • 45
    • Belgique
    I've a receiver Pioneer VSX-922 but unfortunately I can't use it anymore. The MCACC red led is blinking and I can't power up the device. When I try a reset with the Tune down button and the Multi-Zone button, I get the message UPC on the screen for 2 sec and then the receiver shutdown and get back to the MCACC led.
    Does someone know what the UPC message stand for ?
    Thank you
  • bermo96
    • Jan 2019
    • 45
    • Belgique
    Re: Pioneer VSX-922 UPC error
    Does UPC mean microprocessor ?
    • budwich
      • Jul 2015
      • 3097
      likely. Have you tried disconnecting everything from the unit? How did the unit get into this state / history of operation that caused the problem?
      • R_J
        • 9535
        You likely have a bad output stage and the diagnostics is detecting DC on one of the outputs.
        • lotas
          • Jan 2016
          • 4593
          • Russia
          Service manual:
          • bermo96
            • Jan 2019
            • 45
            • Belgique
            Everything is disconnected, I got it used and cheap as a working unit.
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              The TV does not turn on, the standby indicator is on. All voltages are present.
              Emms is dead. Not readable, not detected.
              Replaced emmc.
              But with another dump there is no launch
              Terminal log
              UART
              AC_ON
              RPMB key is not yet programmed
              HASH1_VERSION=0x00000000 64bit
              E-B
              FDE enabled
              layout pattern onebin by SAR7,0...
              06-01-2025, 02:11 AM
            • RatherLoopy
              Pioneer VSX-44 receiver HDMI dropouts
              by RatherLoopy
              I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
              I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
              And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
              05-26-2023, 03:54 PM
            • CdDvdFlash
              Hitachi HTA-DD3W AV Receiver Error Code -Protect-
              by CdDvdFlash
              I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
              07-10-2023, 06:05 AM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
