Pioneer VSX-922 UPC error
  • bermo96
    • Jan 2019
    • 48
    • Belgique
    I've a receiver Pioneer VSX-922 but unfortunately I can't use it anymore. The MCACC red led is blinking and I can't power up the device. When I try a reset with the Tune down button and the Multi-Zone button, I get the message UPC on the screen for 2 sec and then the receiver shutdown and get back to the MCACC led.
    Does someone know what the UPC message stand for ?
    Thank you
  • bermo96
    • Jan 2019
    • 48
    • Belgique
    Re: Pioneer VSX-922 UPC error
    Does UPC mean microprocessor ?
    • budwich
      • Jul 2015
      • 3097
      likely. Have you tried disconnecting everything from the unit? How did the unit get into this state / history of operation that caused the problem?
      • R_J
        • Jun 2012
        • 9634
        You likely have a bad output stage and the diagnostics is detecting DC on one of the outputs.
        • lotas
          • Jan 2016
          • 4936
          • Russia
          Service manual:
          • bermo96
            • Jan 2019
            • 48
            • Belgique
            Everything is disconnected, I got it used and cheap as a working unit.
            • sanalelevenstar
              Yamaha RX-V485 receiver. After encountering a "version error"
              by sanalelevenstar
              I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
              After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
              I managed to find the service...
              09-10-2025, 01:54 AM
            • pixelcap
              Pioneer Kuro Pro 111FD 8 red blink error
              by pixelcap
              Pioneer Kuro Pro 111FD 8 blink red LED.
              I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
              So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
              based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
              10-06-2024, 11:26 PM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • RatherLoopy
              Pioneer VSX-44 receiver HDMI dropouts
              by RatherLoopy
              I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
              I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
              And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
              05-26-2023, 03:54 PM
            • sushilachuthan
              APC UPS error P13
              by sushilachuthan
              one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
              the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
              The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
              We replaced the SCR with new device,, but the device is not power on as expected.
              Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
              09-26-2025, 09:00 AM
