Phonic MAX 860 clip / no output
  • Chrille
    Chrille
    • Feb 2021
    • 21
    • Sweden
    Does anyone have experience of this amp? I've spent ours trying to repair this amp!
    I have several Phonic MAX 860 amplifiers and they ALL have the same problem, more or less!
    This is the thing:
    If I haven't been using the amplifier for a while it goes in to a "no output/clip mode".
    I'll try to explain:
    When I power on the amplifier everything seems to be Ok. I connect a 8 ohm dummy load to the outputs. All still Ok.
    I connect inputs to a signal source and play some music on low volume and everything is still Ok.
    But when I increase the volume a bit, (at least) one channel goes in to some kind of "very very weak distorded output mode". The peak led I lighting and the output turns of (almost).
    Now I have to turn down the volume and wait a while. Sometimes it "comes back" pretty quick and sometimes I have to wait several minutes or longer.
    If I repeat this a few times, and carefully increase the volume until the amplifier goes in to clip (max output), the amplifier works perfectly!
    Now I can play forever and drive it to clip constantly without any problems at all! I can turn off and on and play. All Ok. I can leave it powered off a few days and power on and use it and it works perfectly!
    Now, if I don't use it for, say a month or so, I'm back where I started, i.e. the amplifier goes in to "protection mode" again and I have so "soften it up" again.
    There is no loose contacts or noisy sound anywhere. No scratching sound in the potentiometers at all. When it work, it works 100%
    If you know about this or have experience about similar problems, please help!
    If you don't, please don't try to guess!
    Read this thread instead:
    https://music-electronics-forum.com/...-repair/46505-
    Service manual can be found here: https://cdn.badcaps-static.com/pdfs/...08af00aa0a.pdf
    /Chrille
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • Coert van Dorsten
    Sansui Integrated Amplifier replacement volume control troubles
    by Coert van Dorsten
    Hi all you clever electronmic gooroos!
    I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
    10-15-2025, 02:54 PM
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
    RCA WHP141 wireless headphones wired up
    by momaka
    OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
    Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
    As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
    02-22-2023, 06:28 PM
