D718 & B688 Transistors - Substitutes?
  • redwire
    • 3910
    Re: D718 & B688 Transistors - Substitutes?
    The Technics design looks good, worth restoring. New stuff is so cheap and sounds terrible, hard pressed to use five transistors per channel and overheats.
    The FET phono preamp is nice, I would put in a better op-amp than NJM4559.
    Polar vortex is usually on top of us, or the UK when the gritters come out. -33C last night, time to fire up the tube amplifier.
      I would suggest to put 75W incandescent lamp in series with the AC Line feeeding the unit incase there is is still problem with the circuit so you will not blow up your new Transistors.
      • Nevillet
        • Sep 2019
        • 272
        • United Kingdom
        The transistors arrived today and it's working well apart from the volume and balance. I've tried cleaning with Servisol contact cleaner but they're less than perfect.
        The amp smelt like an ashtray when it arrived and i've managed to clean most of it off bu not inside the pots which may be the problem.
        On the schematic the Vol is marked as 100K (B) and the Bal as 100K (G)
        I guess the B & G refer to the types of taper. I get a bit confused with pot tapers and there doesn't seem to be consensus.
        Can anyone advise.
        • R_J
          • 9540
          Google can help https://eepower.com/resistor-guide/r...iometer-taper/
          "A" LOG, logarithmic
          "B" LIN, linear
          "G" taper (Graphic taper) G taper is reverse audio till midpoint and regular audio after that
          • Nevillet
            • Sep 2019
            • 272
            • United Kingdom
            Many thanks.
            I've used log & lin pots but not graphic taper. I thought that for audio volume controls log pots were used. I need to search my usual UK suppliers for the G pot (as opposed to the mythical G spot)
            I've read the EEPower page you linked to and it was clear - apart from the variance in marking codes.....
            I have a 120W (240V) lamp downstream of a variac to power the amp whilst on the bench and have been using it till now (& until i've proved to myself I hadn't mucked it up)
            I have to say the amp sounds really good with a CD player and driving a smallish pair of HiFi speakers.
            • plyanthony
              Razer Blade 15 no external display with attached screen disconnected from motherboard
              by plyanthony
              Computer in question : Razer Blade 15 2020 Base Model
              Model# RZ09-03286E22
              BIOS CHIP: WINBOND W25Q128BV
              What I'm trying to accomplish:
              I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
              What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
              W/Stock BIOS - 1.06:
              Disconnect the...
              02-01-2023, 09:35 PM
            • redbaron1007
              Sundown SFB-8000D What are these transistors?
              by redbaron1007
              I had a Sundown SFB-8000D amp come into the shop yesterday that wasn't giving any output. The guy who brought it in said he bought it off some crack head on Facebook marketplace for a good price, but bought it knowing it was broken. Apparently the original owner was cutting out the transistors to the right of the ones pictured whenever one would blow and take the output out. Best I can figure he also cut the legs on the S5 and S6 ic's as well and soldered them back together.
              My problem is Sundown decided in the factory to remove the original markings on the IC's and now I can't figure...
              11-12-2023, 07:30 PM
            • Bob Wong
              MSI Crosshair 15 A11UEK. Need help with Transistors!!!
              by Bob Wong
              Welcome badcaps, repairing a Crosshair 15, in need of transistor specifics. Received a broken laptop that's was perfect for repair, threw away the looser transistors in a haste... Should and could have salvaged them.
              In any case, I will be posting all my discoveries to this forum as a thanks in advance. Thanks in advance lol.
              P.S. If anyone is familiar with such things, as in, If anyone knows that MSI uses one or one of a few types of transistors when marked with a number please let me know how I can find more specifics before I start throwing hail marys.
              03-15-2025, 02:02 PM
            • directdrive
              Query - Technics SP10 Mk2 direct drive TT recap
              by directdrive
              I have recently acquired a Technics SP10 Mk2 direct drive turntable from 1981.
              It came from a radio station so I presume it has spent most of it's life in an air-conditioned studio.
              It has a quartz lock system with a number of circuits including a quartz oscillator, frequency generator and phase control ciruits.These are based on (74xx) ICs and it has (x16) (74xx) IC's and (x95) transistors on 3 boards.
              Recently I was attempting to connect some oscilloscope probes to check the control circuit as per the manual and slipped and shorted...
              01-10-2021, 05:56 PM
            • hyva_ana
              Marantz PM-66SE Burns Transistors
              by hyva_ana
              While ago I replaced those big filter caps to that amplifier. After that started to happen. I connected the amplifier normally to the mains and almost immediately several transistors burned out. I really didn't do anything else (at least on purpose) than replaced those big caps C801 and C802.
              After that I replaced those burned transistors (I can't remember exactly what they were) and measured all the others, and now everything should be ok. But, when I power up that amplifier part with two bench power supplies connected in series there is obviously still something...
              02-11-2023, 06:34 AM
