onkyo ht-r290 - My Next Project
  • SolomonMan
    • Apr 2019
    • 206
    Re: onkyo ht-r290 - My Next Project
    Originally posted by tibimakai
    https://www.digikey.com/en/products/...30N-E/11551447
    Select the First class USPS, for cheaper shipping.
    tibimakai,
    Thanks for the suggestion but unfortunately I have already put in the order on Ebay.
    The fellow has quite of few different Amp ICs for sale so I am thinking I should get a good one.
    Looking over the DigiKey site it appears there is also a minimum of 16 on these.
    I have used DigiKey, Mouser, Arrow and Jameco over the years. It seems that shipping is the item that always separates them from competition on Ebay or Bonanaza. I usually try to buy new and from local sources. Local usually means a large order. Ebay usually means a small order.
    Again thanks everyone for the help,
    Chris
    • SolomonMan
      • Apr 2019
      • 206
      tibimakai, madan1, frankusb, and Psmith,
      All thanks for the help on this project!
      It came out successful! The IC came in and I finally got a chance to put it in place.
      It appears from my quick testing that Both A & B & Subwoofers speakers are working properly now.
      The only thing I can say negative is the repair had a few lifted pads.
      As I am a novice still at soldering is that because my heat is to high?
      I have been using a cheapo soldering iron that you get in a kit. I have a couple others that allow heat adjustment including one that is supposedly by the degree (digital).
      I ended up on the lifted pads running a small piece of wire to the next contact point. It was the cleanest and quickest way I could see.
      Again Thanks for the help,
      Chris
      • BOSCHNJAK
        by BOSCHNJAK
        ABOUT ME INTRODUCTION FILE
        2
        024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
        2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
        2022 BEV, PROJECT ?
        2021 BEV, PROJECT ?
        2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
        2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
        12-28-2023, 02:09 PM
      • ngml
        Repair of an LG split AC system indoor unit PCB
        by ngml
        I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
        This indicates an error in the communication between the outdoor and the indoor unit.
        The outdoor unit is fine, so the problem is the indoor PCB.
        The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
        I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
        Does anybody have the schematics of this board,...
        02-01-2025, 12:55 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • DrDos
        Unit runs but no speaker output kenwood KR-6030
        by DrDos
        I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
        09-14-2025, 09:57 PM
      • bauto601
        KDM 480W PSU upgrade succes! (opinions?)
        by bauto601
        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
        A "nice" YoungYear unit? - Badcaps
        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
        12-26-2023, 03:05 PM
