troubleshooting definitive technology prosub 60
  • khajr
    • Sep 2020
    • 19
    Re: troubleshooting definitive technology prosub 60
    I did measure voltage going getting to each of the mosfet pins and everything was zero.
    • khajr
      • Sep 2020
      • 19
      Attached is an thermal image without the mosfets installed. The second pic has the labels. Not sure if this tells us anything. Took the picture with the sub hooked up with the dimbulb test with a 100 watt bulb in it. The bulb dimly lights up for moment and turns off.
      • khajr
        • Sep 2020
        • 19
        Originally posted by R_J
        You need to be very careful working with these double sided boards, If you remove a through hole component and destroy the feed through, you will no longer have the circuit connection between one side and the other.
        Ya. I have been concerned as well and have been checking trace connections above and below the board.
          master hoarder
          • May 2008
          • 12175
          Originally posted by khajr
          I am using a 100 watt bulb in the dim bulb tester. With Q1 and Q7 removed the lit dimly for a moment and went out. Across C2 I get 168v. Across C4 I get 168 v. Across C2 and C4 I get 360v. Across the + and - of the bridge rectifier I get 336v.
          Looks like your power supply, at least on the primary side, is OK.
          Also, I don't see a schematic of a switching PS anywhere after the 200V caps and instead the two 200V caps provide two rails: P170V and N170V. Does this mean this amplifier IS NOT ISOLATED FROM LINE VOLTAGES?
          That would be a very bad design.
          If it really is not isolated by design, I HIGHLY suggest you only use a GFCI plug when you test voltages inside the amplifier.
          I also find it equally appauling that the two 15V power supplies, P15V and N15V are derived directly from the P170V and N170V supplies simply through a resistive drop circuit with Zeners used for regulation. Not only is this inefficient, but it means even the low-voltage rails are not isolated from mains? Am I the only one that's catching this BS, or is the schematic drawn incorrectly?
          *EDIT*
          Looks like there are two P15V and N15V power supplies??? Because one appears to be generated from P170V and N170V on the "line side", as mentioned in the schematics.
          But then there is another set of P15V and N15V power supplies on the "safety side", and these appear to be generated from P32V and N32V power supplies, which come from a transformer, meaning they are actually isolated from the line side. That makes more sense then. Otherwise, I don't see how it would be even possible to sell this amplifier and still meet safety inspections. But then this suggests there are two P15V and N15V power supplies?
          I tested to voltage at the connections for the mosfets and found the following:
          Q1
          P1 and P2 = +169V
          P2 and P3 = -169V
          P1 and P3 = -300mV
          Q7
          P1 and P2 = +163V
          P2 and P3 = -169V
          P1 and P3 = -6V
          I will try and figure what they should be.
          We can try to figure out what they should be as well... but I'm not sure what you mean by those "P1", "P2", and "P3" test points. It would be easier if you use the component pin designators - i.e. Gate, Drain, Source.
          It's normal for the bulb to light up for a moment and then go out when plugging in a device with large input primary caps (i.e. the two 200V caps.) Basically, since the 200V caps are uncharged, they pull a substantial "surge" current as they become charged when the amplifier is plugged in, which is what makes the bulb glow. Once fully charged and at their normal voltage operation levels, the surge current stops and the bulb goes out.
          As for the thermal images... looks like your hottest component are R8 and R6, which shouldn't be surprising at all. These are the resisitive droppers that provide P15V and N15V power supplies. And like I noted above, this is a very inefficient way to do that, so that explains why they are running hot.
          That said, seems like they are running around ~130F (54C), which isn't really that hot. So everything looks OK there.
          However, looks like Q4 is running hot, while Q2, Q3, and Q5 aren't (?)
          In that case, I suggest you remove Q4 and test it out of circuit. Better yet, replace it if you have spares.
          Also check the values of all resistors that connect to Q4. I don't believe Q4 should be running hot at all with the main transistors (Q1 and Q7) removed.
          While at it, also check the voltages across C21 and C27, then report back what they are.
          And if you can, check voltages across C5 and C6 as well (but be careful around these, since they are on the primary side.)
          • khajr
            • Sep 2020
            • 19
            Hey momaka...Sorry I was referring to the pins for that mosfet. 1 is gate, 2 is drain, and 3 is source.
            It only appears that Q4 is warm. I will test as I don't have any spares. I tested R12 and it was fine. I will have to figure out where R5 is. Most of the resistors are soldered right next to the board and I can read the screen printing underneath them but I can figure it out.
            I will also check C21 and C27 and C5 and C6. Thanks so much for your help.
              master hoarder
              • May 2008
              • 12175
              #26
              Ah OK.
              In that case, Q4 and/or the sub-circuit around Q4 are definitely suspect, because you have 6V on the Gate of Q7, which means it's going to conduct as soon as a MOSFET is installed.
              No problems.
              Just to be clear, we are looking for the voltages across these caps (but if you want to take out and check the caps with a cap meter in addition to measuring the voltages, that would be fine too.) An unbalance in the P15V and N15V voltage rails could also be the reason why there is a voltage on the Gate of Q7.
              • finster56
                • Nov 2020
                Good afternoon. I also have a Prosub 60 subwoofer, and it also recently died on me. WhenI discovered your Badcaps thread, I was relieved to find someone else with - I believe - similar issues. My R19 is fried. I just checked Q1 and Q7. They are defective, too. I can replace those 3 components, and am prepared to test and replace additonal ones. However, I see that your thread seemingly ended, mid-repair, a few weeks ago? Did you hit a roadblock? Or - hopefully - did you get your Prosub 60 working? If so, I'd be grateful for any tips/insights beyond those in your thread. Many thanks. finster56
                • khajr
                  • Sep 2020
                  • 19
                  Hello Finster
                  I did hit a roadblock. My driver is bad. The first thing I did was perform the resistance check per DT and checked that the driver movement was free without noise/scratching. After swapping out the components and confirming there wasn't a short anymore I could indeed turn on the sub w/o the fuse blowing or a resistor blowing. I decided to hook it up to the stereo and I wasn't getting a very clear response from the sub. It was low and noisy. I checked the driver again and it scratches now when I apply pressure. I assume the voice coil is bad. Though there may be other components that are still faulty. So, the project is on standby until I get some time to work on it. But replacing the driver may not be cost effective...I am not sure yet...as I am not sure which driver I can buy to replace it. I guess I can get a voice coil repair kit, though I think I would also need a refoam kit. Again...may not be worth it cost wise. I already spent $30 on parts and shipping charges which I was fine with but spending anymore just might not be worth it unfortunately.
                  • finster56
                    • Nov 2020
                    Hello! Thanks so much for getting back to me.
                    Too bad about that roadblock. Yes, DT's drivers are unusual. Mine tested out with a bizarrely high resistance, too. However, I learned from other web sources that this was a design choice (beyond my current technical understanding).
                    If it assists, I recall seeing the identical driver, but used, for sale. It was either on Ebay or Amazon. I think I just searched using the identifiers on the voicecoil shield.
                    May I trouble you for a list of the components you ended up replacing? I appreciate that my problems may be a different, but I suspect they at least overlap. That list should assist me in focussing my troubleshooting. It also will be a wee bit easier to follow than the past thread.
                    Good luck in the meantime with your repair quest. And keep safe. Cheers, finster56
                    • Messor Animae
                      Also have a ProSub 60 that hums.
                      • gica69
                        Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                        by gica69
                        I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                        Resistor shows orange range silver gold and green lines.
                        Thanks in adv...
                        07-21-2025, 09:49 PM
                      • Baste
                        What are the pro's and cons of replacing a 1/4 with a 1/2 resistor same ohms?
                        by Baste
                        As the title says. I bought a cheap Asus ROG Strix 750-watt PSU, which was posted as defective. Cables are complete, and the entire PSU is in good condition, of course, aside from being faulty. Long story short, upon checking, there is no +5VSB. Looking at the components, I found a blown resistor. I swear, looking at the bands, the color is pink, pink, gold, gold. I dunno if I'm color blind or this is the way resistors are coded.
                        Please help, did I decode it correctly at 2.2 ohms (red, red, gold, gold), or what could a pink, pink, gold gold value be? I bought a...
                        10-30-2025, 11:51 PM
                      • jinu_j
                        by jinu_j
                        Hi
                        05-03-2025, 10:51 PM
                      • mikey5791
                        by mikey5791
                        Hi to all forum members,
                        12-26-2024, 04:55 AM
                      • Califauna
                        Help with boom box modification
                        by Califauna
                        Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                        I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                        From factory the specs of the boom box are:
                        -Power Input: DC 5V
                        -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                        -Drivers:
                        -2 x Woofer, 70mm, 10Ω, 70mm,15W
                        -2 X Tweeter, 8Ω, 30mm,10W x 2
                        -Frequency...
                        12-04-2021, 01:53 PM
