Yamaha RX-V673 - No audio at startup
  • Halloway
    • Aug 2020
    my RX-V673 has developed a niggling fault over the past few weeks. At startup there is no sound at all. After a while (20-30 minutes) sound starts coming through sporadically. Then over the next 10 to 30 minutes there are more and longer periods of sound, with some popping and cracking. Then finally the dropouts cease and the amp works correctly and will work correctly all day so long as it's not switched off.
    Further information: all inputs are HDMI. When the sound has dropped out, the front panel speaker icons also disappear. All other functions of the amp seem to work OK. During the 'warm-up' period, the picture is unaffected. The length of time that it takes the amp to start working properly is getting longer every day so I'm assuming that at some point it will stop working completely.
    I don't have very much experience in troubleshooting electronics so I suspect that this fault may be beyond my abilities to fix but any insights or clues as to where to investigate will be gratefully received. I have a service manual but it's too large to upload.
  • wazzadj@hotmail.com
    Wazza
    • Nov 2017
    • 57
    Re: Yamaha RX-V673 - No audio at startup
    Check your output transistor are not bad their is all so a protection capacitor that drives a relay check the monolithic capacitor around the relay channels output
    • tmhobadcap
      • Apr 2019
      • 156
      • CANADA
      I also have the same model with the same problem. I search the internet and someone said heating the dts chip with a hair dryer can make the sound come back temporarily. https://www.youtube.com/watch?v=AQyLaVPQ180
      I tried and yes the sound came back temporarily. I thought that it may be the connections of the legs of the chips do not have good weld at some points. I used a heat gun with a very small nozzle to reflow the welded joints of the legs. After that, I got sound right after turning on. It seems it is working properly now. I will post again if it fails later.
      • tmhobadcap
        • Apr 2019
        • 156
        • CANADA
        Starting 10/29/21, the problem came back.
        • tmhobadcap
          • Apr 2019
          • 156
          • CANADA
          Today, I turned it on and there is no problem.
          • mmartell
            • Oct 2013
            • 3189
            That DTS ic needs to be replaced with a newer version.
            There are many threads here about it. Use the search function.
            • jjne
              Yamaha RX V675 sound issues
              by jjne
              I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
              From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
              At first I thought it was either a speaker relay or the DSP, but I don't think...
              06-24-2025, 07:01 AM
            • i_am_patch
              Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
              by i_am_patch
              Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
              04-30-2024, 08:20 PM
            • Piaskos
              Dell Vostro 5490 - no sound, no audio device
              by Piaskos
              Hi, i've got problem with Dell Vostro 5490.
              Board - Mantis CML 18788-1
              Windows says "no audio device detected". The other functions work properly.
              What i've done:
              1. I checked motherboard
              2. I changed audio codec (ALC3204)
              3. I reflashed bios with clear ME
              4. Audio is enable in bios
              5. Both speakers are good
              6. After installing the drivers from the Dell website, the devices visible in the manager:
              - Audio for intel displays
              - Intel Smart Sound Technology...
              01-30-2023, 02:58 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • CapLeaker
              Motorola Minitor V pager no audio / sound repair
              by CapLeaker
              Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
              Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
              On the main board of this unit where the speaker connects to there is a metal shield....
              06-10-2025, 07:44 PM
