Yamaha P105 digital piano - no standby / no power
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    I received this Yamaha P105 digital piano completed dead - no power and no standby lights. Pressing the power button does nothing.
    I have checked the power adapter has 15V output to the piano. I opened up the keyboard, and did some basic checks, and there is 15V input to the power supply board. But that is apparently no power feed into the main board that connects to the power switch button.
    Attached is the pictures of the PCBs, and the service manual I downloaded.
    I need help to get guide me where to start tracing for problem(s).
    Thank you.
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Yamaha P105 digital piano - no standby / no power
    i take it power comes in on the left side by TH1 ?
    os that a regulator lower left ?
      What DCV do you have at A, B, C, D, E, F, and G with ref to the circuit ground point when Power switch is OFF and when Power switch is ON?
      What is the resistance reading of the Polyfuse TH1?
      See attached picture.
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        Yes, power comes in by TH1, and yes that is a TR2 - TJ20A10M3.
        • beetle1303
          • Jul 2019
          • 279
          • Singapore
          The DCV readings (to be sure I marked on the board the points where I took the reading):
          Power on at the wall socket:
          A = 16.64V
          B = 0V
          C = 0.33V
          D = 0V
          E = 0.06V
          F = 0V
          G = 16.64V
          Pressed the power button on the keyboard:
          A = 16.64V
          B = 0V
          C = 0.33V
          D = 0V
          E = 0.06V
          F = 0V
          G = 16.64V
          **Note that the power button led is never on - no standby light, no power on light.
          The resistance reading of TH1 = 0.07ohm.
            A = 16.64V
            B = 0V
            C = 0.33V
            D = 0V
            E = 0.06V
            F = 0V
            G = 16.64V
            A = 16.64V
            B = 0V
            C = 0.33V
            D = 0V
            E = 0.06V
            F = 0V
            G = 16.64V
            OK, the MOSFET is not being turned on.
            Point 'E' should have about 16V when power switch is not push.
            Check diode D501, D502, R503 (12K).
            We also need to verify if the power switch is OK or not.
            Remove power from the unit, set Ohm meter to 20 or 200 Ohm scale, Black probe on the Circuit ground, Red probe on test point 'E' (PWSW), then push the power switch (it is a momentary type switch), you should see low resistance reading when you push it and high resistance when the switch is released..
            BTW, the test done in your post #5, all the boards and cables are in place, correct?
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              Black probe on circuit ground, red probe on point E:
              Power button not pressed: 80-90Mohm
              Power button pressed: ~3ohm
              D501 (D15?): 750ohm, reversed probes: open
              D502 (D13?): 750ohm, reversed probes: open
              R503 (R26?): 11.96Kohm
              Tests done with all boards and cables connected - except the cable to the keyboard is removed from mainboard.
                So the component designators of the schematic do not match the PCB designator, this will make it a little more complicated to troubleshoot.
                As you can see, the Voltage should be at 'E' where it is connected to the Power Switch (I look through the schematics top find out how the Power Switch is connected), you may what to check the path from point 'E' back to the Gate of the P-CH MOSFET to see why you are not getting Voltage at all on point 'E' when Power switch is not pushed. There is not much just resistors and diode.
                When you press the Power Switch, it brings the Gate Voltage down toward ground so the G-S Voltage is more than 3V to turn on the MOSFET, when MOSFET is off, the Voltage on the Gate and Source will be the same.
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  BUDM - You are a Magician!! A BIG THANK YOU
                  I traced from point 'E' to D15 - and Bingo, the broken spot right at the centre of this path. I jumped the path, and yes, there is light!!
                  A = 16.64V
                  B = 0V
                  C = 0.46V
                  D = 0V
                  E = 15.58V
                  F = 0V
                  G = 16.64V
                  A = 14.78V
                  B = 0V
                  C = 14.98V
                  D = 3.25V
                  E = 3.18V
                  F = 3.18V
                  G = 0.99V
                  Now, a simpler question on how best to mend the broken path - easy way is just jumper up the 2 end points? Or is there a safe way to patch the broken path?
                    Great news.
                    Just use small wire connected to the solder pad of each end of the broken trace on the bottom side of the board, then hot glue the wire down to the board.
                    So is the trace broken due to hair crack on the circuit board? This type of material (paper base impregnated with phenolic resin) used for making PCB do not handle mechanical stress well, they tend to crack, not like FR4 glass epoxy PCB.
                    • beetle1303
                      • Jul 2019
                      • 279
                      • Singapore
                      Great news.
                      Soldered a wire on each end of the trace, and put re-assembled everything back - the very delighted daughter, dis-believing I can repair it with help from Internet
                      Yes, it was a tiny bloated white dot along the path. I thought it was just a dirt/debris, and touch it DMM probe - it immediately "disintegrated" in tiny fragments and revealed the bigger spot that broke the path completely.
                      Thank you once again.
                      • krone
                        • Mar 2023
                        Hi forum,
                        My dad has brought to me a P105, it looks like its had coffee spilt on the power input board. I'm just checking the diodes because D9 looks a bit discoloured and D9 has forward voltage of 0.592V and a reverse voltage of 0.884, whereas all other diodes have only a forward voltage of 0.64V. D9 is also a bit discoloured and looks like it may have overheated.
                        I can't find D9 on the parts list, are all the diodes on this board the same value?
                        Thanks in advance,
                        Krone from Australia.
                        • krone
                          • Mar 2023
                          Hi forum,
                          Thanks in advance,
                          So after months on the shelf I have just managed to get this going again. The problem was shorted D9 and coffee on the PCB / keyboard diode circuit. thanks again =)
                          ^_^
                            • 31063
                            can you backup any roms on it!
                            • psssst
                              Yamaha TSX 120 Standby Problem
                              by psssst
                              Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                              03-01-2024, 07:25 AM
                            • i_am_patch
                              Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                              by i_am_patch
                              Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                              04-30-2024, 08:20 PM
                            • Pianomancer
                              No sound from Yamaha digital piano
                              by Pianomancer
                              Hi All,
                              I have a used Clavinova CVP 209 that isn't playing any sound from the keys or memory, neither on headphones nor line out. The speakers work OK from line in, and the rest of the lights and screen seem to work just fine.
                              I have tried doing a factory reset by holding down the top key and turning it on, but that doesn't help. I did the RAM/ROM checks and they're OK. I checked the volume potentiometer and it seems OK (works with line in audio). I'm thinking it might be faulty DACs from the synth board (IC 28 and 29: ) or op amps. Not sure how to narrow it down more. I've...
                              03-23-2022, 12:11 PM
                            • laidman
                              Yamaha psr ew400 piano loses sound
                              by laidman
                              Yamaha PSR EW400 piano intermittently loses sound and shuts down.
                              Youtube people recommend verifying that the DC jack's solder connections aren't broken, and the replacement of a couple of capacitors in the vicinity of the DC jack. While these solutions might work, I'd feel a lot more secure if I had a schematic to help me check the status of the myriad components.
                              Schematic and suggestions are welcome.
                              11-18-2023, 05:13 PM
                            • hemant_2222
                              Yamaha RX-V373 no voltage on the standby switch
                              by hemant_2222
                              Could someone please advise on this. I have this Yamaha taken from a friend for repair, especially since it had a USB for my interest. But it is not working at all.
                              Here is what has been done so far. Checking the standby switch did not show 3.3 volts on one of its pins, the other was ground. it is showing as 0.60 volts. I have changed the switch as it had some resistance even when normally open. After changing the switch, I next saw that PIN 91 is not showing 3.3 volts.
                              The processor clock pin show 2.8 on pin 18 (XOUT) and 0.80 on pin...
                              11-29-2022, 11:33 PM
