No sound from Yamaha digital piano
  • Pianomancer
    • Mar 2022
    • 6
    • us
    Hi All,
    I have a used Clavinova CVP 209 that isn't playing any sound from the keys or memory, neither on headphones nor line out. The speakers work OK from line in, and the rest of the lights and screen seem to work just fine.
    I have tried doing a factory reset by holding down the top key and turning it on, but that doesn't help. I did the RAM/ROM checks and they're OK. I checked the volume potentiometer and it seems OK (works with line in audio). I'm thinking it might be faulty DACs from the synth board (IC 28 and 29: ) or op amps. Not sure how to narrow it down more. I've scanned the boards for bad capacitors, but only found one that's slightly suspicious but on the mic input circuit which shouldn't affect anything anyway. Does anyone have experience with this? I don't have an oscilloscope so I can't do any precise voltage checks beyond multimeter checks.
    • 31026
    Re: No sound from Yamaha digital piano
    you can use a small amplifier for tracing audio signals - just join the earths together and use the amp input as a probe
    you can start by checking the dac output to see if it's an analog or digital problem
    • Pianomancer
      • Mar 2022
      • 6
      • us
      Do you mean use an audio cable to probe around, and connect the ground section of the cable to the instrument's ground? Should I use a resistor in series for this? It's hard to tell what level of damage I'm dealing with poking around like this
        • 31026
        well if the amplifier is battery powered and you use a film capacitor like a .1uf in series then you can really damage anything unless you probe high voltage like mains
        i used to use an old powered pc speaker.
        • Pianomancer
          • Mar 2022
          • 6
          • us
          I tried probing the DAC output pin using the aux in cable. There was no sound. I was using a resistor though instead of a capacitor... oops. Would that make a difference? Can I conclude from not hearing any signal from the output pin that the DAC is bad? That would mean both are bad, one for each channel.
            • 31026
            resistor will reduce the signal, a capacitor will block dc
            if both dac's seem dead then more likely a voltage is missing or an enable line is missing/stuck
            • Pianomancer
              • Mar 2022
              • 6
              • us
              If you could educate me, why would a capacitor block DC, and why would I want to?
              The DACs are getting voltage and I assume they are getting clock signal from the CPU just fine. I probed the opamps and injected analog signal into their outputs and I got sound, so that leaves the DACs being the problem. I'm not sure how they would both go bad, but it is 20 years old and it was pre-owned so I don't know how long it was operating on mono. I think I'm going to order a couple of these ancient DACs and try to solder them on.
                • 31026
                shouldnt you be injecting sound at the dac output pin to confirm the analog stage is good?
                • Pianomancer
                  • Mar 2022
                  • 6
                  • us
                  I've done both input and output, and got sound on both sides.
                  • i_am_patch
                    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                    by i_am_patch
                    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                    04-30-2024, 08:20 PM
                  • laidman
                    Yamaha psr ew400 piano loses sound
                    by laidman
                    Yamaha PSR EW400 piano intermittently loses sound and shuts down.
                    Youtube people recommend verifying that the DC jack's solder connections aren't broken, and the replacement of a couple of capacitors in the vicinity of the DC jack. While these solutions might work, I'd feel a lot more secure if I had a schematic to help me check the status of the myriad components.
                    Schematic and suggestions are welcome.
                    11-18-2023, 05:13 PM
                  • jjne
                    Yamaha RX V675 sound issues
                    by jjne
                    I have an old Yamaha RX V675 receiver which is starting to develop issues with the sound, although it doesn't quite match up with what folk normally report with these.
                    From cold, the sound cuts in and out. When this happens the amp is losing sync with the optical input (speaker graphic disappears from the front panel). But this is not resolved by putting the unit into pure direct mode. After a couple of minutes this resolves, although there are occasional clicks from the speakers after that.
                    At first I thought it was either a speaker relay or the DSP, but I don't think...
                    06-24-2025, 07:01 AM
                  • AlexVG
                    YAMAHA CLP-550 without of sound
                    by AlexVG
                    Hi.
                    I have an old YAMAHA CLP-550 without sound. (Some times I can get some kind of noise or distorted sound)
                    I have replaced all green marked elements, but it gave me nothing.
                    The IC12 chip LC9116A-105 (red marked) remains under suspicion yet.
                    But it is custom YAMAHA's chip, and I can't find any information about it.
                    Maybe somebody came across with the same issue?
                    Any information will be very useful. I will be very appreciated.
                    Thank you....
                    06-08-2025, 09:29 AM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
