LG SJ4 Soundbar stuck in loop
  • mstaglicic
    • Oct 2017
    • 9
    • Croatia
    I have an LG SJ4 Soundbar which stopped working. When I press button to turn it on, it load only Optical mode. After few seconds LED start cycle from all inputs around and then I cannot even turn it off by button or remote, only by unplug cable from jack on rear side.
    When I turn it on again it is in the Optical mode again for few seconds then again LED goes in cycle and it is not respond to any button or remote control .
    Is there any reset combination ( I havent found any ) or maybe some other option to solve this problem ?
  • ashtastic
    Samsung Soundbar HW-K550 stuck in power cycle loop
    by ashtastic
    Hey All!
    Having an issue with a soundbar (Samsung HW-K550) wondering if you guys could help. When you plug it in, it immediately starts a 2 second power cycle, where it will turn on, then off 2 seconds later, then on, over and over. I checked the output from the power cord and the adapter which seems to be fine.
    I can't find a service manual for that exact model, but I'm wondering where to start to look for issues... I have a scope and all the tools required to potentially fix it, but just not the knowledge
    I can post pics of the board/power supply...
    08-08-2020, 09:30 AM
  • nono34
    Hisense stuck in Colors cycle like test pattern.
    by nono34
    I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
    I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
    10-24-2024, 04:31 PM
  • Yanleb
    Samsung 4K UN55NU7100F stuck in a reboot loop
    by Yanleb
    Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
    I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
    I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
    On a few occasions I found that reconnecting the disconnected LVDS...
    03-19-2022, 02:13 AM
  • phantomEVO
    820-00840 stuck at 5v on port a, 5v loop on port b
    by phantomEVO
    Hi guys i have an 820-00840 that not boot... (stuck at 5v)
    here there is the history of previous techician (i can't say if it is 100% true)
    macbook dead
    found a short with thermal camera on c3000
    caps removed (not replaced)
    tried to charge -> smoke
    found u3100 burnt
    changed, no luck
    changed u3200 no luck
    rechanged u3200 with the original one. No luck
    now i have this laptop.
    i have discovered that i have 5v @0.20a STUCK on usb port connected on 3100...
    08-07-2023, 02:05 PM
  • Faluky
    firmware for Marantz SR5008 stuck in update loop
    by Faluky
    After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
    Best regards.
    Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
    01-17-2023, 04:33 AM
