RME Octamic II input circuit anyone
  • Andrealikescaps
    • Dec 2013
    • 17
    Hello Badcappers.
    I just finished wasting time contacting RME for any useful information on the Octamic II preamp. We have been repairing these for some years (with no help from RME). These are expensive devices with cheap unreliable components inside. Caveat emptor.
    Anyway, we are managing to repair them all the same, usually by replacing the dodgy switchmode power supply with something reliable, but recently I thought it would be nice to actually repair one of these devices, rather than replacing boards in them. A likely candidate came along with just one channel out of 8 showing no output. Surprisingly, this one actually had a working power supply, which was nice.
    Measuring voltages I could see 9VDC on the negative side of most of the caps in the faulty channel. Obviously not meant to be there, especially when compared with the other channels.
    Anyway RME wouldn't even drop a hint as to how their input is wired and the attached guess is just a guess. So cut a long story short, anyone ever mapped out the input to ANY similar RME devices as I'd bet they all are the same?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: RME Octamic II input circuit anyone
    Short answer, yes, but there are several variations. You could consider starting with some well-lit (ie. not dark, but no flash-glare either) and well-focused photos of one channel.
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Andrealikescaps
      • Dec 2013
      • 17
      Thank you Khron, is this photo ok?
      • CapLeaker
        Leaking Member
        • 8196
        probably some transistor went south. what is the marking on the 3 legged SMD part? is there anything on the bottom of that circuit board?
        • Khron
          • Sep 2006
          • 1350
          • Finland
          That's a bit on the dark side, but anyway... So you're not seeing a signal on the ADAT channel 8 (where the ch8 preamp is routed)? Or the analog output 8 is dead?
          • Andrealikescaps
            • Dec 2013
            • 17
            Thanks for the suggestions. I've uploaded more photos. No signal on ADAT or analog output on channel 4. All the rest OK.
            All the caps except the largest and smallest on the left have around +9VDC on the can, as pictured.
            Disconnecting the 48V power feed to the board does not make the stray 9V go away, so not caused by those diodes. Removing the ADAT board makes no difference either.
            To answer Capleakers sensible question, there is nothing under the board as pictured. The 3 legged device is marked "1 GM" followed by what could be a sideways "N" or a squashed "Z". Photo attached.
            • Khron
              • Sep 2006
              • 1350
              • Finland
              The can is not necessarily connected to anything, so... I'm not 100% sure what exactly you're measuring. For reference, i just measured a couple Rubycon electrolytics i had on the bench here, and my meter's showing 1.8-2Mohms (that's mega-ohms, millions) between the can and either leg.
              "1G" seems to correlate with a number of different NPN transistors - my guess would be, they switch the phantom-power on and off for that respective channel.
              Any chance you can get enough glare-less lighting on the board where you wouldn't need to use your phone's / camera's flash?
              I wouldn't remove the various DC-blocking electrolytics from suspicion. But some more "overall" photos of the board might help with at least getting a feel for the structure of the preamps.
              In a pinch, assuming you've got a signal source you could set to 100Hz or so, you could try tracing the path of the signal with your multimeter - the AC range should be capable of measuring 100-120Hz frequencies with some degree of accuracy.
              • Andrealikescaps
                • Dec 2013
                • 17
                Thanks again. I have measured the same voltages at the board as on the Caps can. I know there isn't necessarily a hard connection to the can, but it makes an easy measuring point, besides for a high impedance voltmeter, 1Mohm is no obstacle to measurement.
                The stray 9V seems to be coming from the IDS connector pictured, 5th pin from the top right.
                I'll pull the front panel board, also pictured, and follow this stray DC voltage in.
                You are correct. The 1G transistor is 48V power feed and since that is disconnected, not relevant to this problem.
                Audio does seem to push through the DC, past the diodes, at an attenuated level. I'm pretty sure once the DC is removed, the audio will behave normally.
                A circuit would help this a great deal. It's a shame RME are so insecure about their products that they won't share service material.
                • Khron
                  • Sep 2006
                  • 1350
                  • Finland
                  Those big 6.3V caps in and around a mic preamp start to take my thoughts towards a pretty classic mic preamp design.
                  https://sound-au.com/project66.htm
                  Could one or several of the input transistors have become electrically leaky and "produce" that 9V offset?
                  And/or it might be interesting to know what voltages the analog circuitry's powered with.
                  • CapLeaker
                    Leaking Member
                    • 8196
                    measuring voltage on the cap lid like shown in the first 2 pictures in post #6 is wrong. you need to measure the legs of the cap.
                    • redwire
                      • 3910
                      It looks like a vanilla mic pre-amp front end. It's common for these to get zapped by transients from the phantom power or ESD. Note OP's pic has four components not populated which are likely protection diodes.
                      I would check the 470uF 63V input coupling caps have not shorted as a side effect.
                      When phantom power is on, they see 48V on (+) and 0V on the other (op-amp) side, which is normal.
                      With phantom power off, 0V on the (+) and with a failed op-amp say -9V, which is reverse polarity for them.
                      The 3,300 6.3V cap is for the mic pre-amp op-amp (gain control) so the voltage on it will tell a lot, if the IC is OK.
                      Measuring voltage touching the can of an electrolytic cap doesn't work- it did 40 years ago with can-type electrolytics, but now you're just measuring leakage to the can which can be higher than the multimeter's input resistance and inconsistent readings. It just leads you on a goose chase.
                      • Andrealikescaps
                        • Dec 2013
                        • 17
                        "That 1510 preamp IC" may be the problem.
                        Tis an 8 pin package.
                        Pinouts and recommended circuit attached.
                        I measure:
                        Pin 1 Rg1 -9.8VDC
                        Pin2 -in -9.1VDC
                        Pin3 +in -9.1VDC
                        Pin4 V- -15V
                        Pin5 Ref 0V
                        Pin6 Out 0V
                        Pin7 V+ +15V
                        Pin8 Rg2 -9.8VDC
                        So. How is it possible for Rg1 and 2 to have a higher (absolute) potential that +-in other than the chip is faulty and conducting some of the -15V supply to Rg1 nad 2.
                        Does this seem plausible or likely?
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          I assume all the other channels have pins 1-3 and 8 pretty much around 0V, right?
                          If that's the case, then sounds like that preamp chip is indeed at fault.
                          • jantoman
                            • Jul 2013
                            • 18
                            • Italy
                            Hi. On my desk there's an Octamic with a PCB severely damaged by a shorted diode. The device turns on, but there's no dual voltage on pins 4 and 8 of the 4580 op-amps. Andrealikescaps, would you be so kind to take a snapshot of the PS input section and post it here? If you still need information about the mic input circuit, just let me know (although there are probably many differences from Octamic I and II).
                            PS Please note that, as you can see in the attached picture, I removed the transformer to clean and repair the PCB.
                            • Andrealikescaps
                              • Dec 2013
                              • 17
                              "That 1510 preamp IC" was indeed the problem. Replacing it fixed all.
                              Unfortunately this preamp has left the building jantoman, so it can't pose for a picture, but when another comes in I will take a picture.
                              • Andrealikescaps
                                • Dec 2013
                                • 17
                                BTW if RME ever get around to reading this post (they said they would when I contacted them), please understand that sharing technical information on your products helps to increase your standing in the community. This has value beyond measure if you want to survive in the long term.
                                This is something you will learn if you stay in business long enough.
                                • Martin_CZ
                                  • Jan 2021
                                  • 9
                                  • Czech
                                  Dear guys. I spend about 8h with trying to repair RME Octamic II. There were 2 inputs bad - very strong noise at these inputs and signal very low. I tried to replace THAT1510 and NJM4580 to new ones, still same problem. Then i cutted tracks at input PCB (board with XLR connectors) and connected symetric signal from input 1 (bad) to input 3 (correct working before) at control panel. After this, input 3 was bad too. So I localized problem at input board. Finally i found bad serial resistor 4R7 Ohm (meassured about 8kOhms). After replace both of ressistors the device works correctly.
                                  • прямо
                                    • Sep 2022
                                    • 261
                                    • Indonesia
                                    The channels are all identical, so you can find the problematic component very quickly by just comparing the measurement on the bad channel vs the measurement on the good channel. Would have saved you 8 hours
                                    • eccerr0r
                                      old X58 triple channel board... memtest86 memory speed?
                                      by eccerr0r
                                      Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                      Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                      Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                      06-28-2025, 09:06 AM
                                    • karatzdi
                                      Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                      by karatzdi
                                      I know some might say... just buy another one. Sell it as parts..!
                                      So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                      Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                      Spent some time downloading the Service...
                                      06-11-2024, 08:38 AM
                                    • ugamazing
                                      820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                      by ugamazing
                                      So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                      1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                      2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                      04-10-2024, 08:06 AM
                                    • CDNBrewer
                                      Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                      by CDNBrewer
                                      Hello Everyone,
                                      I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                      Symptoms:
                                      • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                      • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                      • I swapped the Left and Right surround
                                      08-05-2025, 09:29 PM
                                    • mikey5791
                                      Help on car amplifier only one channel works
                                      by mikey5791
                                      Hi all forum members,
                                      Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                                      My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                                      08-06-2025, 10:36 PM
