Kenwood dnx890hd navigation white-ish screen problem
  • topfli8979
    • Oct 2012
    • 311
    Anyone ever repaired a Kenwood navigation double din unit. Have newest software and 2020 map update. Have done a hard reset numerous times. Every once in a while the navigation will work. But more times than not , i just get a white screen and says maps unavailable very dim. Kenwood wants $175 just to look at it....
  • tibimakai
    • Jan 2012
    • 3680
    Re: Kenwood dnx890hd navigation white-ish screen problem
    Here at City of Industry service center, is way cheaper to diagnose it, ~$40.
    In the settings, the 2020 map is selected?
    • topfli8979
      • Oct 2012
      • 311
      Yes 2020 map is selected. I talked to Kenwood yesterday and they are thinking navigation reflash. $175+ shipping. Crazy expensive to hook a cable up and run a program in my opinion.
      • tibimakai
        • Jan 2012
        • 3680
        In these units there is a small board called daughter board. On it there is a micro sd card with the nav software. Maybe the software on that card, is corrupted.
        I would take it out, and try to copy/paste the content on a pc, and see if it will show any errors. There are some files/folders on it, that are not visible to Windows, because they are in a different file format.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
        • ipatch
          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
          by ipatch
          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
          08-24-2024, 02:36 PM
