Reel to reel tube recorder Geloso G258, problem
  • Lef de art
    • Oct 2019
    • 26
    • Cyprus
    Hello my friends.
    I have bought recently a almost unused reel to reel tube recorder, Geloso G258 feom 1958
    But because of his age it is time for changing his electrolytic capacitors.
    I leave in Cyprus so it will be more easy for me to buy them on line because here i don't have many choices in electronic components.
    The capacitors i need are the following.
    *16μf 200ν-250v
    *32μf 350v-500v
    *25μf 30v
    *150MF 15v
    *0,0047μf 20%
    *0,0022μf 25%
    and one double/dual capacitor 25+25μf 200vcc-350v (if i write it correctly)
    Please if you can help me will be a huge help.
    Thanks in advance
    Sorry for my bad English
  • redwire
    • 3912
    Re: Reel to reel tube recorder Geloso G258, problem
    Axial electrolytic capacitors are hard to find. I don't know what parts are available in Cyprus.
    I use radial capacitors and bend one lead over. A little bit of silicone caulk/glue to hold it down. Modern capacitors are so much smaller.
    16μF 200V (250V surge) - use 16μF 250V
    32μF 350V (500V surge) - use 33μF 450V (two needed)
    25μF+25μF 200V dual (350V surge) - use two 22uF 250V
    25μF 30V - use 33μF 50V
    150μF 15V - use 220uF 16V or 25V.
    0,0047μF ?V 20% - use 4n7 400V mylar film cap like Epcos B32529C6472
    0,0022μF 630V 25% - use 2n2 400V mylar film cap like Epcos B32529C6222
    Geloso G258 Schematic: https://www.eserviceinfo.com/downloa...loso_G258.html
    • Lef de art
      • Oct 2019
      • 26
      • Cyprus
      Really thanks Redwire.
      I will try to find them here but really is difficult in Cyprus.
      There is not any on line way to buy them ?
      • Lef de art
        • Oct 2019
        • 26
        • Cyprus
        The only 16μF 250V capacitors i can find are for starting motor use with no polarity .
        Can i use no polarity capacitors ?
        • Lef de art
          • Oct 2019
          • 26
          • Cyprus
          I have ordered them, so just waiting to arrive
          Thanks Redwire. Your help was really big.
          One more question. I must change and this one.
          Any idea with what type and what uf ?
          Electrolytic one ? Bipolar or not ?
          • redwire
            • 3912
            You are over 5,000 miles around 9,300km away. I don't know electronics parts distributors over there. RS Components might be good but they like to sell bags of 5 or box of 1000.
            The 0.1uF 400V cap connects to mains, so I would use a film cap 275VAC 0.1uF with X-cap safety rating. Look at Epcos B32653, Kemet R46 series.
            • Lef de art
              • Oct 2019
              • 26
              • Cyprus
              You are my Hero
                https://www.badcaps.net/forum/attach...3&d=1571582161
                That is a snubber cap for the switch (it is connected in parallel with the AC switch contacts).
                • Lef de art
                  • Oct 2019
                  • 26
                  • Cyprus
                  Is a important capacitor for the system ?
                  It must be changed or does not really matters ?
                  It is a papper capacitor so for sure does not work correctly any more.
                    It helps to reduce switch arcing, you should replace it since it is old paper based cap.
                    • Lef de art
                      • Oct 2019
                      • 26
                      • Cyprus
                      Thanks Budm.
                      I have ordered them and i wait to receive them so i can start the replacing process.
                      It will take some time to receive them but i will update the forum with the process
                      • Lef de art
                        • Oct 2019
                        • 26
                        • Cyprus
                        Hello again guys.
                        I have changed the electrolitic and papper capacitors and the problem is resolved. The recording and erase process now works normally.
                        But i have noticed that when i power on the system, the middle lamp 12AX7 , lights really much for 1/2 seconds , then decrease and remain in the normal light as the other lamps .
                        I believe it is over voltage in first 2 seconds because of some capacitor.
                        Any idea ?
                        This happens only when the system is off for at least 10 minutes.
                        This does not not happen to the other 12AX7 , 6AQ5 or to EM84 lamp.
                        • redwire
                          • 3912
                          This is normal - when the tube is cold, high current surge for the heater and the fine wires will light up bright orange until the heater is warmed up.
                          Geloso put two 3.3R resistors for tube V1a heater but not the second 12AX7 for some reason. It might be for lower noise and hiss.
                          • Lef de art
                            • Oct 2019
                            • 26
                            • Cyprus
                            Thanks Redwire .
                            It is the lamp. I have changed the position with the other 12AX7 and the phenomenon occurred in the same lamp but this time in the different positions.
                            As i understood is not something important. Does not mean the bulb is defective so everything is ok
                            • Lef de art
                              • Oct 2019
                              • 26
                              • Cyprus
                              Comparing the sound i have now with the sound i had before changing the capacitors i have the filing that i have lost enough bass, low frequencys.
                              As it is normal in the replacement capacitors process it wasn't easy to find the exactly value in capacitors. So some changes was made...
                              There is any chance the following replacements to be wrong?
                              What is your opinion?
                              0,005uf / 150v replaced with 0.0056 250v
                              0,002uf / 400v replaced with 0,0033 400v
                              0,025uf / 300v replaced with 0,027/ 400v
                              0,5uf / 150v replaced with 0,56/ 250v
                              Or this differences are not important?
                              Thanks in advance guys
                                If the coupling cap between audio stages has decreased value then you will lose low end frequency, but you put in higher value so it should not decrease the low frequency response. The Cathode bypass caps will also affect the low frequency response.
                                https://www.v-cap.com/coupling-capacitor-calculator.php
                                • redwire
                                  • 3912
                                  I would say those differences do not matter, the capacitors are tiny bit bigger and would not make the bass go weak.
                                  You must have mixed up a capacitor, or a new one is no good, or polarity backwards (for 25uF), or there is a wiring mistake putting in the new capacitor.
                                  Check the capacitors, I think important (for bass) are:
                                  25uF 30V cathode pin 2 EL95 electrolytic
                                  20K 150V grid pin 7 12AX7 V1a
                                  25K 350V plate pin 6 12AX7 V1a
                                  10K 400V plate pin 1 12AX7 V1a / pin 2 12AX7
                                  • Lef de art
                                    • Oct 2019
                                    • 26
                                    • Cyprus
                                    Thanks Redwire. I will check them today.
                                    The electrolitic capacitors work all good because i have changed them all in first stage and i then the recording quality was ok.
                                    After i change all the papper capacitors the recording high frequencies are very weak.
                                    And the recording sound has more treble.
                                    But the changes are in recording .
                                    • Lef de art
                                      • Oct 2019
                                      • 26
                                      • Cyprus
                                      The difference is on recording high frequencies .
                                      The recording has lost high frequencies.
                                      The playback mode with old capacitors recordings sounds ok.
                                        Did you check/adjust recording bias? Tape heads are cleaned and de-magnetized?
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • perzyk23
                                          Lenovo T580 - LCD Panel problem - error 0288
                                          by perzyk23
                                          Good morning,
                                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                          10-25-2024, 12:42 AM
                                        • lazaro.089
                                          Asus Zephyrus M16 / GU603ZW problem
                                          by lazaro.089
                                          Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                          CPU: Core i9-12900H
                                          Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                          Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                          The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                          08-26-2025, 06:33 PM
