Need Firmware for M-Audio Audiophile USB
  • Roman78
    • Oct 2017
    • 54
    I am a collector of old and vintage computers and hardware. Some time ago i bought a M-Audio Audiophile USB to run on an Apple Cube. The device worked only ones now it does not get recognized by any system. I tried Windows 98, XP, 7 and OSX 10.4.11, 10.6.8, 10.10.5. It does not even show up in the device manager. But after i removed the Firmware chip it get at least recognized, but as unknown USB-Device. So i thought to open a post here, because i already got some help here with Firmware for my Philips 20" Monitor from 2001.
    Now i got a simple eprom burner for modifying my iMacs BootRom and this one is also able to read and flash the eprom of the Audiophile. The chip is a MicroChip 24LC64. I could read the information from the chip and saved it. This is an 8KB chip. So does someone have a Audiophile USB and can make a dump of the Firmware, or maybe has some firmware somewhere?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Need Firmware for M-Audio Audiophile USB
    See if you can contact this guy, maybe? The post's 4 years old, but who knows, maybe he's got the dump saved somewhere still.
    https://getsatisfaction.com/m-audio/...iophile-eeprom
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • Roman78
      • Oct 2017
      • 54
      Thanks. I hoop he gets a notification. I could not send an email, so i posted in the thread.
      My idea was also to buy an other one and use that firmware. Hmmm maybe i should backup the Firmware of my Audiophlie Firewire also.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        ... Or that - might be quicker and more certain. And sure, as long as you have the tooling.
        I took that route with many of the interfaces that passed through my hands.
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
        • Slapito
          Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
          by Slapito
          I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
          Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
          I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
          I already downloaded the BIOS update file from msi official...
          10-09-2025, 02:00 AM
        • angelos
          Eprom dump versus firmware update
          by angelos
          I have a interesting question but does anyone know the following.
          If i flash a tv with a firmware update and then i remove the memory ic 25Q32BVSIG, a 4mb SPI chip and read the contents with my programmer and compare the two image files (Dump versus firmware) are they going to be identical.
          What I want to get at is that if I have a firmware update and I try to download it directly into the SPI chip will it be successful? Will it work. So far I never tried it because I assumed it will not be the same. Anybody know?
          Regards
          Angelos
          03-18-2022, 12:44 AM
