sony SA-CT60BT soundbar problem
  • bob_rich
    • Nov 2015
    Hi
    I have repaired the unit once before and it had the swollen capacitor problem changed it out for new and all was OK but it failed again. Opened up and it had another swollen capacitor but this time canning it out still no good.
    the unit is totally unresponsive to the controller ( which seems to send a signal OK) after digging around I found theta the capacitor I changed the second time has no volts across it. Further checks suggested the power supply ( based SSC620 chip) is either in s standby type of mode. Two other supplies read around 29V and 3.5V.
    welcome any further tips or ideas. have wondered about changing out all the capacitors. Also there is a small circuit board on the right hand side looking from rear with cover off fed with a red and white lead--any idea what this does.
    any ideas would be most welcome
    bob
    • Jul 2011
    • 6069
    Re: sony SA-CT60BT soundbar problem
    Please post some pictures of the boards in it
    • Retro-Hipster
      Tinkerer
      • Apr 2019
      • 125
      Oh, also, on that capacitor where there are 0 volts if you do a continuity test from one lead to the other do you have a low ohms link/short? Honestly, if failed capacitors are a theme with this unit it would probably be worth checking all of the tank capacitors at least. (Anything remotely high capacitance)
      If you have an ESR meter that would help. If not, having an oscilloscope + signal generator can be even better for testing stuff in circuit quickly. It also can help you distinguish between a super low ESR and a short. (Putting things in DC coupling and keeping the in-circuit test current low, like 250mv with 100-250MHz will help you distinguish between a short vs a low esr.)
      Note: Unless you are intimately familiar with a circuit/know where parallel capacitors are, it is always better to test out of circuit. Actually, it is just always better, but you get the point. lol
      “Men always seem to think about their
      past before they die, as though they were
      frantically searching for proof that they
      truly lived.”
      – Jet (Cowboy Bebop) -
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • crackedprint
        Sony HCD-HX80R Amplifier Volume Control Problem
        by crackedprint
        I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
        I have tried a Cold Reset as per the service manual.
        I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
        I have looked all the way through the service manual and tried many online...
        01-21-2025, 12:18 PM
      • jaaa1976
        HP EliteDesk 800 G4 Mini PC -There is a problem with the security device on the unit
        by jaaa1976
        Hi everybody !
        I bought this pc from ebay with error - There is a problem with the security device on the unit
        please fix my bios.
        Model: HP Elitedesk 800 G4 mini PC (65w)
        serial no. 8CC93326J4
        PRODUCT NO. 4KW04ET#ABU
        32- 16mb bios attached
        Thank you so much...
        12-19-2024, 06:48 PM
      • retrorepair
        SONY KDL-40P3600 Picture Problem
        by retrorepair
        Hello gurus, hope you can assist me...
        I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
        I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
        Thanks in advance.
        10-11-2024, 05:12 PM
      • guruji
        Sony mbx-266 problem
        by guruji
        Hello
        I this Sony mbx-266 it powers
        on all the voltages are normal the strange part iOS the caps key num key works which shows the machine has booted but no video at all internal dp and the ext vga or hdmi.I have changed the bios but same issue. What do I check ??
        07-25-2025, 08:10 AM
