BKElectronics XLS200 problem
  • OniJon
    Computer Expert
    • 82
    • Finland
    Hi!
    Having weird issues with this subwoofer amp. Once upon a time it buzzed when in standby and no signal coming in, I changed few little caps and this fixed the problem for many years to come. Now this thing started to take huge load of the wall, tripping the breaker and making varying scratchy sounds with no input. I've measured main caps with Peak Atlas ESR70 and they seem to be fine. There is one tiny Nover cap 10uF 50V, it has ESR of 2ohms. Is this normal or should it be lower? Manual of the meter says that 63v 10uf could be as high as 9ohms and still be good but I can't be sure about this because it's in German.
    I'll check connections closer and resolder ones that look bad but other than that, I'm pretty lost with this.
    • 31214
    Re: BKElectronics XLS200 problem
    one of those bright orange film caps looks absolutly fucked!
    it's almost shedding it's coating!!
    • OniJon
      Computer Expert
      • 82
      • Finland
      It's just illusion on the photo, it looks all good in person.
        • 31214
        where is the big cap that is not on the board?
        • bulkchart32
          i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
          by bulkchart32
          i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
          06-16-2025, 03:09 AM
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Zeonalbasta
          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
          by Zeonalbasta
          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
          09-13-2024, 01:17 PM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • perzyk23
          Lenovo T580 - LCD Panel problem - error 0288
          by perzyk23
          Good morning,
          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
          10-25-2024, 12:42 AM
