Cress Audio Vs900
  • Irvin1
    • Sep 2018
    • Grenada
    Cress Audio Vs900
    Hi there,
    I have a cress Audio Vs900 amplifier which has power issue and need some guidance in it's repairs. The problem is that the surge protector onboard has burnt out (I don't know what caused it), however, I replaced it with another I removed from another power supply (both resistors had no ratings on them) which burned out as well. I then removed it and soldered the connection and now the amp powers on and off consistantantly. Can anyone guide me on what step to follow next? I believed that something else gone bad on the board.
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Cress Audio Vs900
    Are you sure that's not CresT?
    You can find the service manual over here:
    Any chance you could snap a couple of (well-focused and glare-less) photos of that "surge protector"? I'm not sure i can see anything like that in the above-linked document. I'm guessing it's on the primary (mains) side of the power transformer?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
    • nobbnobb1
      Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
      by nobbnobb1
      I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
      https://www.digikey.ca/en/products/d...0D241K/2799098
      The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
      06-04-2025, 08:40 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • i_am_patch
      Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
      by i_am_patch
      Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
      04-30-2024, 08:20 PM
    • silver60618
      Macbook M3 A2991 Speaker Audio Amplifier IC
      by silver60618
      Im working on a 2023 Macbook Pro M3 A2991, that had a liquid spill, has no sound. Corrosion found near Speaker Audio Amp IC. Chip ID SN012776B0,
      I did find a SN012776B0 on A2442 model, but the sub and replaced it, no go. Anyone know if these audio amp IC's are cross compatible between 2021-2023 models?...
      09-26-2025, 12:25 PM
