Help with capacitor choice
  • Henchman
    • May 2009
    Hopefully someone can easily point me in the right direction.
    I have a Denon amp that has some bulging caps and has started to switch itself off after a few seconds of being on.
    the caps have the following written on them.
    Sanwha
    DL 85 C (M)
    63wv10000uf
    for Audio
    Rough Dimentions are
    6cm tall
    3cm diameter
    1cm Gap between the pins.
    I've done some searching, and I'm not sure of the different type of caps. I'm in Australia, so hopefully there's somewhere that ships internationally etc.
    Much appreciated.
  • Toasty
    • Jul 2007
    • 4171
    Re: Help with capacitor choice
    Do you mean SaMwha?
    Samwha does not currently list a DL series. Probably discontinued, and their discontinued list does not show them. Perhaps too old? How old is the unit?
    Check your dimensions carefully. Approximate measurements won't cut it for the new caps if they have to be mounted tight to each other. Cap dimension measurements are typically given in millimeters.
    Try a Nichicon KS (preferred) or the KG series.
    Digi-key doesn't offer KG & is non-stocked on KS & minimum 200 order. LOLz
    Mouser.com
    They only show 1 (KS) in stock and 0 on order. arrgh!
    Mouser #: 647-LKS1J103MESC
    Manuf #: LKS1J103MESC
    No experience with this company but pointed to by some audio forums for the KG series:
    http://www.minisemi.com/
    http://www.minisemi.com/Nichicon%20M...apacitors.html
    Good Hunting!
    Toast
    veritas odium parit
    • Henchman
      • May 2009
      Thanks heaps, that's much better than I could find.
      The caps aren't that close together, so it should be fine.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • devsigner
        identify capacitor for MacBook Pro with rare logic board 820-02037-06
        by devsigner
        Hi
        While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
        resistance tests show a rising resistance value, indicating a capacitor.
        The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
        i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
        It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
        11-28-2025, 01:39 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
