Philips HTS9140 3d Bluray , Which caps needed?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    I sold my other philips soundbar and bought this defective soundbar. I had the HTS7140 before hoping this one would be even better but unfortunately it is just software and a little design. Boards are all identical.
    So all these sets have problems with the main cpu ( bad bga ) and the capacitors going dead.
    I fixed the "starting" problem by reflowing the main cpu and fixed the "speed" of starting up with replacing the capacitors in the powersupply.
    With blu-ray it sounds really amazing. Clear sound with a nice bass , nothing to complain there. However , when i connect it via optical in/hdmi and just play some netflix from tv it does not sound good at all. I had the same problem with the HTS7140 and tried different tv's. It sounds a bit hollow and the middle/high tones are more on the background and bass is more up front. Just not clear sound.
    So either this soundbar is designed for bluray only OR there is something wrong on one of the boards with the optical input?
    All boards have cheap chinese capacitors. ( Brand = chong ).
    Picture attached is the board with optical input.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Philips HTS9140 3d Bluray , Which caps needed?
    So basically i want to change the capacitors on the mainboard. Is there a specific brand that i should use for these type of boards? Panasonic?
    Ps this is not the actual board. It's a scrap board.
    Service manual here :
    https://www.electronica-pt.com/esque...22e/no_html,1/
    • CapLeaker
      Leaking Member
      • 8327
      looks to me some did some work on IC103? btw, when I click on the link for the service manual, I get a 404 error.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        https://www.electronica-pt.com/esque...-ver1.2-33760/
        Yes this is not the actual board but it is the same as in my soundbar.
        • re-atari
          • Oct 2010
          • 136
          So the pcb in the pictures is not your board? If it is, you might want to check connector CN4001 (bottom right), judging by photo 1 it has a bent pin inside the connector. Beside that, the board's overall build quality isn't quite overwhelming.
          Groeten,
          re-atari
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Groeten,
            re-atari
            The board on the picture is exactly the same as in my soundbar besides the soldering etc.
            The build quality is indeed very very bad and ALL boards have cheap chinese capacitors on it. Even the small display.....
            I had the HTS8161B before , sold it. Owww wish i didnt!!!
            I just checked what capacitors each board has and ordered Panasonic replacement parts. Hopefully it will help because the design is really nice.
            • dragos2009
              • Mar 2013
              • 110
              • Romania
              i would suggest you to change all the caps on the logic board and you have a pin crooked in connector cn4001 you need to fix that aswell
              • Daniel Larsson
                Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
                by Daniel Larsson
                My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
                I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
                During these seconds the function button is not working...
                08-13-2025, 10:29 AM
              • zyklop
                Philips Soundbar TAB8507B/10 stopped working
                by zyklop
                Helllo everybody....
                i have this soundbar to repair for a friend. Its finally 2 years and seldom used but already broken.
                Inbetween it has one time started, but no more yet.
                Is anybody who has schetatic or service maual ?!
                Power supply seems to be ok and has stable 24V DC. No control line or somthing else...........
                No thermal hotspots or something else controlled with thermal imaging cam.
                No reaction on remote control (function ok, can see it while glow into mobile-camera)
                No shorts to detect.
                ALso tested all reset procederes...
                07-07-2025, 05:08 AM
              • trunks81
                Philips HTS7140 Soundbar
                by trunks81
                Hello
                Got this soundbar and problem is that is not powering on, And before that the unit display is gone, while the unit was working
                I measured the PS and only got the 3,3V do i need to shortcut 3,3V with the on/off on the PS ? and can i use an 1K resistor for this...
                08-23-2020, 05:07 PM
              • StasNep
                Philips HTL6140B/12 SoundBar no power
                by StasNep
                Hello
                I have got a defective Philips HTL6140B/12 SoundBar, no power from button or remote.
                The power supply is external and working correctly, even tried another one.
                Checked caps with esr meter and all seems ok.
                Checked various resistors and smd capacitors and they seems ok.
                Please help to diagnose this SoundBar.
                Thanks ...
                02-20-2022, 10:37 AM
              • alro7779
                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                by alro7779
                Hello, guys!
                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                09-14-2025, 12:25 AM
