Strange device on A/V cables
  • Tom41
    • Oct 2005
    • 339
    • England
    You've probably all seen the cables that convert a 'headphone' jack to two phono plugs.
    I've seen a strange, cylindrical object on many of these cables, particularly the ones that come with digital cameras for audio/composite output to TV. It's usually positioned nearer the 'headphone' jack, not the phono plugs.
    Does anyone know what it is, and what it's used for?
    I vaguely remember taking one of these things off an old broken cable and hacking it apart to see what was inside. It just seemed to be made of solid metal underneath the plastic; no electronics at all.
    I would assume it's some kind of filter, but I haven't been able to find any information about these things on the Internet..
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • jpdoe
    • May 2007
    • 237
    Re: Strange device on A/V cables
    Here you go:
    http://www.ce-mag.com/archive/02/11/may.html
    • Toasty
      • Jul 2007
      • 4171
      It's a choke to filter spurious harmonics and interference from the signal generated by the input device. Usually made of either ferrite or iron powder.
      veritas odium parit
      • Wizard
        • Mar 2008
        • 2296
        Yes, this is ferrite bead filter (choke). This doesn't let getting past anything that has EMI.
        Cheers, Wizard
        • trunguntilyou
          Inspiron 5406 If the device only plugs in the battery, the device will not turn on
          by trunguntilyou
          Most of my devices cannot turn on with the battery (sometimes they still turn on). When I plug in the charger or both, it turns on normally. When I plug in the battery, it turns on and has 3v, 5v, 1.8v, (when each battery is not turned on, there will not be these 3 sources). In addition, there is no power even though Anyway, now I just need to plug in the charger, and the device will automatically turn on and turn on normally
          st H0ZTM93
          19860-1
          Link to boardview/schematic - https://www.badcaps.net/forum/showthread.php?t=119432
          Reminder: rules and organization...
          10-22-2023, 10:51 PM
        • Yolofolkss
          Asus X99-pro/usb 3.1 Usb overcurrent device reoccurring issue
          by Yolofolkss
          Hi this is a really odd case.
          I have removed all of the esd ic for USB 3.0 and 2.0
          I measured all of the data lines and 5v usb voltage lines there are no shorts
          all of the USB ports have no damage
          Clearing the bios using the jumper wont help.
          it is still showing USB overcurrent device
          the only temporary fix I've tried and worked so far is flashing the bios
          and the error is gone
          but when you start the motherboard with a USB device still attached
          the USB over current device error is back. the bios needs to be externally flashed...
          01-09-2023, 04:21 AM
          RJ45 Block Diagram / Schematic
          RJ45 network connectors are most commonly found at either end of an Ethernet (wired internet) connection. At first glance, they appear similar to the familiar telephone plugs and jacks which connect landlines to walls or switchboards. However, RJ45 connectors are typically slightly larger.
          The term RJ45 connector is widely used today to describe both male RJ45 plugs and female RJ45 sockets. The plugs, sometimes called modular connectors, are usually found on the end of Ethernet cables. The sockets or jacks are generally embedded in the device...
          10-31-2024, 04:18 AM
        • Stachujones
          Dell XPS 13 9370 unknown USB devices in device manager
          by Stachujones
          Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
          Device manager says "unknown device, failed to request device descriptor"
          Can somebody point me in right direction what to check?
          I updated bios to the newest version and thunderbolt controller firmware still no luck
          04-05-2025, 07:35 AM
        • bohaboha
          how to install gl usb2.0 uvc camera device driver on windows 10
          by bohaboha
          Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
          but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
          any help?
          01-26-2025, 08:33 PM
