Soundcraft UREI 1601 - master bus problem
  • kr315
    • Apr 2018
    • 6
    • Poland
    Hi Everyone,
    I have a problem with UREI 1601 which is a digital DJ mixer. There is no sound on MASTER OUTPUTS despite the fact that on MASTER CUE everything works fine. I checked control voltage on master pot, there is none. So I'm looking for the source of the CV, and also the source of signal for IC10 which is MASTER OUTPUT buffer, but it is a multilayer board and I already spent a two days on it. Does any one have any clue? Or maybe schematics? I could not find one anywhere. Or some advice from more experienced circuit expert on how to look for it.
    I asked for help at Soundcraft support but they're not responding.
    https://www.soundcraft.com/en/products/urei-1601
    Something about the device:
    There is a DSP board with buffers, ADC/DAC and BLACKfin processor.
    There is Control Surface board with control voltage (CV) pots and faders, ADC for CV, some buffer stages (there is the one for MASTER OUTPUT on NE5532).
    Two I/O boards but they don't play any role in the problem.
    I'm a new guy on the forum so don't hesitate to comment on how poor/good is the info I provide, please be forgiving or something
  • R_J
    • Jun 2012
    • 9535
    Re: Soundcraft UREI 1601 - master bus problem
    This should help. Do the VU leds indicate anything? Do you have booth out?
    • kr315
      • Apr 2018
      • 6
      • Poland
      Geeez, how did you get it? Nevermind. No VU, don't show anything, no signal on booth out. I'm getting my hands on it with the schematics. Thank you very much!
      • R_J
        • Jun 2012
        • 9535
        I have the technical manual , it shows the block diagram
        • kr315
          • Apr 2018
          • 6
          • Poland
          R_J, you have some really nice stuff.
          I found out that DAC (IC4 on DSP) does not give output. All the voltages around IC4 are exactly the same as around IC5 and IC6 which are working fine, IC4 gets the same data on inputs, so that's why I think it's a DAC failure. I'm almost sure..
          • hardnoize
            • May 2018
            • Croatia
            Thanks R_J. I'm trying to find schematics for urei 1601S last 10 years!
            • kr315
              • Apr 2018
              • 6
              • Poland
              Problem solved, DAC replaced after month of shipping
              • aragorus
                • Jun 2021
                • Denmark
                I'm having an issue with my UREI 1601 and I can't decide where to start looking. It has this clicking noise on all outputs (master, booth, cue).
                And inputs too (it's outputting the click on the inputs jacks too)
                https://soundcloud.com/tsvnst/urei-clicks/s-AZKWAwjr9gx
                Has anybody experienced this before?
                • crackedprint
                  Sony HCD-HX80R Amplifier Volume Control Problem
                  by crackedprint
                  I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                  I have tried a Cold Reset as per the service manual.
                  I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                  I have looked all the way through the service manual and tried many online...
                  01-21-2025, 12:18 PM
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
