Pioneer XR-A670 cd changer mechanical issue
  • mike_drz
    • May 2017
    • 43
    Hello all, I've been fixing up an old cd/tape/stereo bookshelf type unit. I cleaned the rail for the laser and greased it all up. That fixed the first issue where it wasn't reading the disc. To my great joy, there's another problem.
    The CD clamp rubs against the top assembly, causing the CD not to spin, or make noise if it does. If I push down in the middle of the assembly, then it'll play just fine. I tried bending the plastic, and it'll work for a few minutes. Now it's back to not working.
    Am I missing an adjustment anywhere? Is there supposed to be a rubber part at the top of the disk clamp? Maybe something fell off and got lost causing the gap to shrink?
    Any help would be appreciated, thanks in advance !
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    Re: Pioneer XR-A670 cd changer mechanical issue
    The most common cause of this issue is that the rubber shock absorbers (4, one at each corner of CD mechanism) are decaying. Since it’ll be difficult to find exact replacements, I recommend to add some cardboard supplement below them, in order to elevate the mechanism 1-2mm.
    • mike_drz
      • May 2017
      • 43
      Originally posted by Chungalin
      The most common cause of this issue is that the rubber shock absorbers (4, one at each corner of CD mechanism) are decaying. Since it'll be difficult to find exact replacements, I recommend to add some cardboard supplement below them, in order to elevate the mechanism 1-2mm.
      Chungalin, that is genius! That never came to my mind at all while looking at it. I will take it apart and give that a try. Thanks so much for your advice
      • R_J
        • Jun 2012
        • 9546
        Another thing to check is the spindle on the motor shaft, they can, over time be pushed down the motor shaft enough to cause the top clamp to rub, sliding the spindle up very slightly can fix this issue
        • mike_drz
          • May 2017
          • 43
          RJ, it's been a while. How have you been? That's something else I'm going to check out. I have put it on the back burner for now, as the workbench has a wood working project on it right now.
          From what I recall, the spindle looked like it was on a bit of an angle. It's as if the whole assembly is not coming up all the way. It's on a spring from what I see in the service manual. I'll take a look at it soon enough; and let you guys know.
          Mike
          • R_J
            • Jun 2012
            • 9546
            It could be that the mechanism is slightly out of alignment, maybe out one tooth causing the cd mech. to not come up fully, or bad drive belt.
            Did you have the servo mechanism out and the rubber float feet off? they are different between the rear two and front two, they are usually different colors, if they are backwards the servo mech. will be crooked.
            looks like #23 AEB7063 are the front (nearest the spindle motor) they are blue
            #24 AEB7066 are the rear, they are black
            • mike_drz
              • May 2017
              • 43
              It looks like a combination of things causing the problem. I took the mechanism apart for the first time. The black rubber floats are chalky in colour. I took them all out, and sprayed them with some silicon spray. The motor shaft does have some vertical play on the shaft. The bottom end, or end cap of the motor is sealed. I can try slide the top of the spindle up a bit.
              The tilt mechanism appears to just be a cam, when the cam unlatches, there's a spring that pushes the whole thing up and level. I stretched out that spring a bit.
              I don't have any washers or spacers for the floats, so I'll put it back together as is, and see where I'm at.
              • mike_drz
                • May 2017
                • 43
                No dice, the unit plays fine for a little bit, and then starts rubbing again. I tried pulling the spindle up, but it's friction fit pretty tightly. I used a wooden block with a screw head sticking out of it that goes on top of the spindle. Then I pulled up on the spindle head. It wouldn't budge, even when oiled. I was afraid I'd bend the spindle head.
                This thing is all plastic, it doesn't seem to be pioneer's best work. It even uses screws as shafts, if you tighten them too much, things will bind.
                • Longbow
                  • Jun 2011
                  • 623
                  Replace the rubber mounts as suggested. Spraying them won't do anything.
                  Is it plugged in?
                  • R_J
                    • Jun 2012
                    • 9546
                    If you want to move the spindle up a bit, I use a flat blade screwdriver between the motor and the spindle, twist the screwdriver a bit and the spindle should move up, don't pry it or use too much force, this also works to remove the spindle if the motor needs to be replaced. pulling on the spindle itself can break it or deform it
                    Or it could be that the plastic on this unit is warped a bit, they are cheaply built
                    • rounin
                      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                      by rounin
                      I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                      🛠 Original Issue
                      The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                      04-19-2025, 01:18 AM
                    • GraphicMan
                      Pioneer A-205 faint noise/hiss issue
                      by GraphicMan
                      as the title says, i noticed a faint noise/hiss when there is nothing playing that i dont think i have had with this unit before ever, i have not changed its location
                      what makes it more weird, this noise is gone almost completely if my hand gets within 5cm or less close to it (close to the panel)!!
                      out of curiosity what does that mean?
                      thanks
                      05-19-2024, 11:45 AM
                    • ugamazing
                      Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                      by ugamazing
                      I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                      We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                      12-17-2024, 07:05 PM
                    • ahmarzo
                      Acer laptop battery draining issue
                      by ahmarzo
                      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                      08-02-2025, 06:39 AM
                    • Simone Vergani
                      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                      by Simone Vergani
                      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                      To assist with troubleshooting, I'm attaching two power circuit schematics:
                      • Power
                      03-05-2025, 02:25 PM
