Re: Marshall Stanmore Repair
I have one that is experiencing option #4
I'm going to change the 3.3uf 50v cap. OF course its marked C4! BOOM! lol
i'll post back if it works.
Thanks everyone for the contributions
Hi Hann,
I've read your post with great interest.
My Stanmore is also down, no led on at all, just earing a little click, for a few seconds, at the start.
No success after replacing the MC34063A, the LM317T and FMG23S.
So I would like to make your solution (replacing the 3.3/50), but I don't see it on the PCB...
Could you please give me its place and its reference ?
Thanks a lot.
Best regards.
Michel (from France).
is it defective?Leave a comment:
Hi Hann,
Thanks a lot.
Best regards.
pls see attachedLeave a comment:
Hi Hann,
Thanks a lot.
Best regards.
pla see my drawn schem its near OB2269Leave a comment:
Hi Guys,
I have just joined this forum to be able to talk to you.
My stanmore is not powering up either.
Basically what happened:I unplugged it from the socket while it was playing, and ever since there's no pilot light and power.
I found the fuse blown so i replaced this, this gave not a lot of joy. While i was clapping happily for the fact the pilot light came up by the time i clapped twice it went out again.
I took out the big board and looked for damaged components but found nothing yet.
I did some measurements around the diodes to make sure they are not blown they seem alright. Now the speaker is just eating fuses. It looks like a dead short but i cant find the short.
Do you have any idea what it could be? What should i look for?Leave a comment:
Data sheet: http://www.ti.com/lit/ds/symlink/tas5342a.pdfLeave a comment:
I'm still looking for a schematic/ service manual for this amp.Hope someone can help with a copy or a link?
Posts in other repair forums mention the use of cheap chinese 'ChenX' caps on this board that leak electrolyte. Caps with Marshall goop poured around them had corrosion hiding underneath which destroyed a number of SMT components. I believe some of these design issues were addressed in the Mk2 version.Leave a comment:
Update:
The power amplifier was fried and the 7812 IC together withthe shorted D7 located underneath. Everything replaced except the amplifier.
The unit started up and this time the bluetooth worked as wellCould easy pair it so there is hope for the unit but we see when I receive the power amplifier.
The amplifier IC has the marking 42TTI A87CG4 (?) but someone else suggests that it could be a TAS5342A IC?
Has anyone information what the amplifier IC could be?Leave a comment:
Interesting thread. I have replaced the burned R23 (220 ohm) with a bigger resistor underneath the PCB. I have attached a picture so you can see how I have done it.
I have also a picture for you who have problems finding the 3.3 uF capacitor.
PS still broken but faultfinding is still in progress.Leave a comment:
I took several months off trying to fix mine, maybe will give it another go since in the meantime I got some parts for it I ordered from China. My speaker blows fuse and I hope it is something wrong with P/S part of the PCB, like the bridge diode or the MOSFETLeave a comment:
So I received the replacement IC chip (MC34063API) and after a long and arduous effort to solder this larger thru hole component onto a surface mount board, the original intermittent bluetooth problem persisted...
I have already sent the speaker to the authorized Marshall repair shop out of province for $35 CAD to get it fixed.
Hopefully they don't have an issue with the fact that I have a jumper wire from one of the IC pins to the connecting smd capacitor as the damn pin track came off as soon as I touched it with my solder wickLeave a comment:
hi everyone
i am new to fix my Stanmore
my Stanmore while playing music , sound went on and off all the time
with some strange noise before went off.
anyone know how to fix it?
appreciatedLeave a comment:
I just got this device from my friend for repair.
Where this 3.3/50 cap is located on PCB?Leave a comment:
Also, if anyone has had success swapping out the 8-pin surface mount DIP MC34063A who was experiencing my issues (Case#1, Bluetooth connecting but no sound), I would be very grateful if you could try to guide me in how to check the voltage on the part, and anything I need to be aware of when replacing. I have a basic multimeter, and an OK soldering iron kit. My experience is beginner in the electronics field, I've successfully swapped out a damaged micro USB port on a Logitech Bluetooth speaker, so I have confidence in my soldering abilities.Leave a comment:
Hello, I purchased a used Stanmore (1st edition) and while the unit turns on, LEDs working, Bluetooth connecting and staying a solid red LED, the sound will turn off when switching media apps (playing music, then playing a YouTube video, then back to music). The issue is very odd, as sometimes when I unpair and re-connect to Bluetooth, music will play, and sometimes it won't at all no matter how many times I try to unpair, unplug, and reconnect...
Speaker works just fine when connected to AUX... I have been able to replicate these no-sound issues with BT over 3 phones in total (Galaxy S7, A50, and iPhone 6S).
Marshall is willing to repair the issue (non-warranty repair), having me pay for shipping. But if I can repair by swapping out a 10 cent part, then I would prefer to try that. However, I'm not sure if Marshall would still repair if I opened up the back...
So has anyone here experienced my issues with speaker working fine with other inputs except no sound on Bluetooth even though it is connecting successfully?
Thanks.Leave a comment:
Hi Hann,
Thanks a lot.
Best regards.
Michel (from France).Leave a comment:
Im trying to repair my Marshall now, and i see that c9 is burnt, what part is that?Leave a comment:
Greetings...I was looking around for a schematic for the Stanmore and came across your discussion. I should pop in more often . I usually park my brain in some other forums :-)
Anyway ,the unit I received for service did not have audio. Unit came on with LED ,etc. I found that U15, audio output IC was cooked. I replace the IC, however I still have no sound. All voltages appear to be good. I can see audio at U19 (in/outs) . I see audio going into U4, but nothing coming out, data or analog. There could be a micro/software issue not enabling this IC, or something else. Seeing how U15 imploded pretty good, I suspect that it may taken out something else. Man , a schematic or even a block diagram would be great right now. It's fairly easy to obtain and replace U4 , which I'll do , but looking for other suggestions ...Thanks !!!
For reference:
U15 : TAS5342A(digikey)
U4: PCM1808 ( digikey)
U19 : HCF4052Last edited by jabase; 10-07-2019, 10:37 AM.Leave a comment:
Put a lightbulb in series before powering up.Leave a comment:
3. If a surge occurred and replacing the fuse doesn't solve the problem, this could be a fault of the primary (power supply) or secondary (cold) side of the PCB. ...The power supply is a 100-240V SMPS with some "standby mode" circuitry thrown in for European compliance.
As for my problem, I wait for the mosfet and rectifying bridge to arrive in mail but replacing them is just a shot in dark.
I think the big clue for fuse blowing might be my measuring 'open circuit' on A/C 120V input when there is no power supplied - yet once AC is connected, the fuse blows, indicating short circuit.Leave a comment:
by Kezi GamerHi, recently i have encountered problem with my Marshall stanmore multi room speaker, speaker itself works fine using app from my phone but knobs on actual speaker doesn't work. First thing that came up to me is that maybe something is shorted on the top board and after disassembling the speaker and checking with multimeter I could not find anything wrong, also on the panel multi, and next song button are working and nothing else. Any help is very appreciated...1 Photo
03-24-2025, 08:37 AM -
by jingleslacksHey Friends!
I have both a live and demo unit. Demo unit firmware disables Bluetooth, power toggle, and other settings. Resets via button combos will not work on these. Reaching out to Marshall is not an option either.
I copied my live CMOS chip and flashed it to the demo unit, but that didn't fix it (MX25U3235F) This has worked for other devices in the past. I'm not a chip expert, but I'm assuming the firmware is stored in another chip.
If anyone has any experience or ideas, let's hear them!
Stanmore II
Stanmore 2...-
by thuygsmhello
in my case, the Bluetooth - AUX - RCA signal light goes off after 5 seconds and repeats, (sound is there then 5 seconds then gone and repeats)
i forgot them and reconnected, but they do not play on the speaker, although i can still adjust the 3 modes Bluetooth - AUX - RCA (on the phone)
after i loaded a new rom, i lost bluetooth connection and could not power off, no boot sound. i loaded the previously saved rom again, but the situation still cannot find bluetooth and boot sound
hope everyone can help
by ohrenHello!
I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
Measured voltages with no load:
After rectifier diodes
12V: 6.17 V
5V: 5.67 V
Secondary transformer pins AC measurement (really don't know if this says anything)
12V: 2-2.5 V
5V: 1.04 V
I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,... -
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
- Loading...
