Problem on YAMAHA RX-V379 receiver
  • Flaviocb22
    • Dec 2017
    • 4
    • Brazil
    Hi guys,
    i'm new on the forum. Recently i bought a Yamaha Rx-V379 receiver. Yesterday i was playng some game and suddenly the receiver turns off appearing CHECK SP WIRES. I turn on again with the protect bypass procedure and appears DC- PRT 000L. Consulting the rx v377 service manual (i think its almost the same schematics as the V379) it says the this is caused by an abnormal DC on power amplifier. The 000l says that no current is been measured at pin 141 of IC. I went to self diagnosis menu and it says that on DC is 000 when it should be between 058 - 088. But the other stuff like PS, USb, etc are all on normal range Any tips what could cause this? I'm suspecting on a output transistor but anyone of you have similar problem?
    PS: sorry about english. I'm brazillian.
  • Flaviocb22
    • Dec 2017
    • 4
    • Brazil
    Re: Problem on YAMAHA RX-V379 receiver
    any help?
    • mmartell
      • Oct 2013
      • 3189
      So check the output transistors for shorts. Just use a meter on them without removing.
      • sanalelevenstar
        Yamaha RX-V485 receiver. After encountering a "version error"
        by sanalelevenstar
        I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
        After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
        I managed to find the service...
        09-10-2025, 01:54 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • falcontech
        Yamaha Msr400 Input Board Problem
        by falcontech
        Good morning everyone
        I have a problem with this input module of an active speaker of the Yamaha (MSR400), the signal transmitted by this unit and sent after the EQ module and then end up the amplification form is lower than normal, I attribute the problem to this Module because with that of the twin box works perfectly, I thought of the three capacitors highlighted in the photos and that I have not yet replaced or the operational highlighted NJM2860L, the strange thing I noticed that by trying with the jack by pulling it a little out of the normal position the earnings is normal, while...
        04-06-2023, 09:44 AM
      • pulper111
        Pioneer VSX-1123 Receiver - weird voltage problem
        by pulper111
        Hello. My receiver "seems" to be working fine. It functions as it should. the receiver is the Pioneer vsx-1123. However, while doing some work in the house, I noticed that my HDMI cable from the receiver was registering as "hot" using my fluke non-contact voltage tester.
        I've done some troubleshooting to try to narrow down the problem, and all wires (speaker/hdmi/subwoofer) coming from the receiver, whether it's powered on or stand-by, register as "hot". none of my other receivers are experiencing this issue, so it doesn't seem to be an issue with...
        09-02-2020, 11:12 AM
      • Capestang
        Yamaha DSP-AX861SE Sub problem
        by Capestang
        I really hope someone will be able to help me?
        I have recently moved house and dismantled a working 5.1 home cinema
        system. Unfortunately when putting it back together again I get no
        sound out of the sub, I'll try and give you as much (probably too much)
        information to hopefully allow you to sort my problem, or at least
        point me in the right direction.
        * My system consists of a Yamaha DSP-AX861SE AV receiver connected to
        various sources and outputting through speaker cables to 4 x Monitor
        Audio Radius 90s, 1 Radius 225...
        01-24-2023, 04:00 AM
