Hi i recently got Onkyo rx sr607, the problem was it have no sound even in any mode, then i checked the DSP chip, i found that it getting very hot, so i suspect there some internal short inside, I ordered new chip same part number and i replaced yesterday, But sill have no sound , i checked the voltage rail it is in limit as per schematic 1.2 volt and 3.3 volt. but when i am checking the DSP version on Display its showing D: ??/ ????????? like that .. i will appreciate anyone help on this
Onkyo tx sr 607 -New DSP chip installed
Re: Onkyo tx sr 607 -New DSP chip installed
I wonder if the DSP chip might have some internal EEPRROM / flash memory, where it has (or should have) some ID and/or configuration data programmed...Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans -
I can't be sure, but i wouldn't be surprised. Either way, i'm pretty sure (detailed) datasheets can't be found for those custom(?) chips.
That being said, if it has a flash chip nearby, that could be part of the problem too.Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - ShenanigansComment
HI... good news.. i kept in on condition this onkyo more than two hours after that i just checked the dsp firmware version ,,, success in display its shwoing the version.. but i dont know how it came..i connected speakers and i got sound,, but i restarted the again but its gone.. again display shows bunch of questions mark in dsp firmware.. but now i am kept it on conditionComment
Hi ,,, i sort out the problem now .. the problem wass improper soldering ,, one pin of DSP chip ws not solderd properly ,,i soldered it again now its ok:musics
i reach a conclusion now ,, there is no flash rom inside the DSP chip itselfComment
SRT1, are there any other BGA chips on your board?
To me, seeing that it works after a few hours of idle time makes me think that there is a thermal issue, like a bad solder connection which expands and makes connection after the PC board warms up.
-BenMuh-soggy-kneeComment
no other bga related to sound processing . my problem was bad soldering of dts chip ..Comment
