Bose PS18 III looking for power block schematic
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Power block part number is 286612-002
    Thank you
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Bose PS18 III looking for power block schematic
    https://elektrotanya.com/bose_ps18_p.../download.html
    • Pragmatiko
      • Jul 2013
      • 468
      • IT
      Thank you very much Moreno
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        No problem! It is a rar file , hopefully you get what you need. I have a macbook and no rar program so i didnt open the file.....
        Elektrotanya is a good source for files!
        • Pragmatiko
          • Jul 2013
          • 468
          • IT
          Yes I know,also I am member of Elektrotanya and file you linked already have. Maybe Bose made revision on power board and in that rare is not present. However
          ihave appreciated your info. Thank you again.
            So what is wrong with the power supply board?
            If you upload good clear straight shot pictures of the top and bottom side of then board then we may be able to help.
            • Pragmatiko
              • Jul 2013
              • 468
              • IT
              Thank you very much Budm, but client want back not repaired set. However, there was many short component on primary circuit.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
                03-31-2024, 02:12 PM
              • Russ1
                Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
                by Russ1
                Sick of seeing big numbers of these routers dead no power light underneath.....
                Chasing Schematic of this power supply I have searched high and low....
                Already spotted a few swollen caps, but Ac fuse ok.....
                This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
                Can anyone help with any type of schematic and parts list ?
                Thanks and Regards, Russ
                07-10-2025, 11:01 PM
              • meraklinetx
                Asus Z97-a power cycle, no boot no cpu voltage
                by meraklinetx
                Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                05-10-2023, 06:08 AM
