Onkyo TX-SR875 Remote corrosion.
  • Number 47
    • Aug 2013
    • 19
    • Ireland
    Hi guys,
    Bit of a catastrophe, batteries leaked in my remote and now the IR is not working. Found the damage, I'm handy enough at soldering but I have no idea what to do with this. Can anyone advise if this is repairable? If so, how to go about it?
    Much appreciated.
    • 31015
    Re: Onkyo TX-SR875 Remote corrosion.
    clean in with vinegar,
    that will remove the corrosive.
    then use a meter to check the tracks.
    personally i would rub it down to clean copper & tin it.
    • Number 47
      • Aug 2013
      • 19
      • Ireland
      I have cleaned it with vinegar, had a rub at it with an eraser. Lost my multimeter recently in a messy divorce so I will have to buy another tomorrow.
      The copper is badly damaged as are the tracks by the looks of it. When you say rub it down and tin it I'm assuming you mean sand off the copper and replace with solder?
      Sorry, I've replaced caps and done automotive soldering etc but this is new to me. Is there a way to repair the tracks too if damaged? Can i run a wire or something?
      Many thanks for your help.
        • 31015
        not sand, it will go through the copper.
        i use the back of a blade, or a flat screwdriver.
        just to remove the green layer and any corrosion.
        then as you say, use the iron to coat it in solder.
        • mmartell
          • Oct 2013
          • 3189
          Yes you can run wires in place of the tracks if you know where they run to.
          • Number 47
            • Aug 2013
            • 19
            • Ireland
            Thanks guys, can't do this at the moment due to being skint and not being able to afford a new multimeter but I will return with results when I have it done.
            • mmartell
              • Oct 2013
              • 3189
              Skint = broke I take it ?
              • Number 47
                • Aug 2013
                • 19
                • Ireland
                Exactly that. Family court eating my money.
                • cstout
                  DeLonghi AC Remote only accepts 3V
                  by cstout
                  Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                  The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                  I can't find any schematics...
                  06-03-2024, 03:53 PM
                • Mc_Millian
                  Toshiba 50lf711u20 fire tv remote not pairing
                  by Mc_Millian
                  I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                  The Tv model number is: 50lf711u20 Rev B.
                  I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                  I've tried 3 different remotes which should be fully compatible with this TV.
                  Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                  The power button, along with the volume,back,select, and directional...
                  04-07-2022, 12:15 PM
                • edugimeno
                  HiSense 55A7500F won't obbey to remote after power on
                  by edugimeno
                  Hi! I have this TV set that does the following:
                  1) I press the red power button on the remote
                  2) The TV turns on normally
                  3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                  4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                  Then after it's off, it would again accept the TURN ON from the remote and same again
                  BUT:
                  -The remote does show the correct IR beam while observed thru a phone camera
                  -The TV works fine while using the MiRemote...
                  03-14-2023, 11:22 AM
                • tmhobadcap
                  Pioneer VSX-522-K remote control not working???
                  by tmhobadcap
                  I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                  At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                  12-24-2020, 01:44 AM
                • rustinjust
                  Please help, where can I get a remote for my subwoofer?
                  by rustinjust
                  I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                  Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                  Is there...
                  10-28-2023, 03:43 AM
