Audio through left and right at same time
  • titomno2
    Gaming Laptop Zephyrus S17 TFT not detected every time !
    by titomno2
    Hi guys,
    I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
    So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
    On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
    Then the screen won't work for a long period of time.
    If I wait 1 or 2 hours it work again most of the time.
    When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
    01-19-2025, 08:27 AM
  • flat-earther
    Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
    by flat-earther
    I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
    To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
    I have opened the camera and I think there is enough room to add something inside to accomplish this:
    The camera is powered by a 3.7V nominal single cell lithium ion battery.
    So I need to connect another battery in...
    06-08-2025, 02:00 AM
  • Pinky Deepak
    Vizio M60-C3 Left Edge problem
    by Pinky Deepak
    I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
    Here's a video of both the issues: https://youtu.be/hMqc760nB3o
    09-27-2024, 05:11 PM
  • OscarAV
    HP Pavilion dm4-1065dx long time to get the power led on
    by OscarAV
    I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
    I have made a quick search for my laptop but I have not seen anything similar.
    I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor...
    09-23-2024, 05:53 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
