TOA BG-130 Amplifier power supply fuse blown
  • fuxxy
    • 318
    Re: TOA BG-130 Amplifier power supply fuse blown
    So I checked the main power transistors (attached to the heatsink) using the "Diode" function on my DMM.
    The results are a little confusing.
    The first two D2059 transistors have similar results.
    Pins 1 & 2 = .538
    Pins 1 & 3 = .541
    Pins 1 & 2 = .540
    Pins 1 & 3 = .542
    I get no other readings ("OL") using any other polarity or pins
    The second two B1367 transistors are wildly different from each other
    B1367 #1
    Pins 1 & 2 = .523
    Pins 1 & 3 = .525
    No other readings using opposite polarity, like the D2059's.
    B1367 #2
    Pins 1 & 2 = .027 (Both polarities - odd!)
    Pins 1 & 3 = .463
    Pins 2 & 3 = .459 (Didnt get this read on the other B1367!)
    D110 is a "15b2" silkscreened label
    Reads "OL" one polarity, 0.650v the other way
    D109 is a "15b2" silkscreened label
    Reads "OL" one polarity, 0.642v the other way
    R179 i can't identify. I've included a pic so you guys maybe can read what exact colors those might be
    It reads 0.664 kOhm with my multimeter.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Looking like a 1K resistor and something is wrong with that 2nd 2SB 1367 PNP Transistor. These reading were taken in or out of circuit??
      • R_J
        • 9549
        the diodes would be 15 volt zeners, they seem to be in series, so thats around 30 volts, Not sure what the voltage is on the main filter but i would guess aroud 40-50 volts, I suspect the resistor is ok, it is discolored but my guess is 680 ohm
        I would remove that #2 2sb1367 and check it out of circuit, I suspect its bad,
        It looks like the 2 npn outputs are driven by one driver, through its own base resistor and the 2 pnp's are driven a similar way
        I bet the BG-115 only has on each npn & pnp and this being the 30 watt version uses 2 transistors in parallel, I know what I would do to check the amp
        I suspect you found the problem, those readings are enough to cause the amp to draw too much current but not being a dead short did not blow the 3 amp dc fuse, thats my guess,
        • fuxxy
          • 318
          All those components were tested out of circuit.
          Output of the primary transformer is right at 40v
          Would I be able to run this amp with one complementary pair of transistors, and the other set removed?
          If I can't find a source for the KEC B1367, can I replace it individually with the NTE equivalent - or would I need to replace both in the pair?
          EDIT:
          I'm showing the NTE replacement for the D2059 is NTE54, and the B1367 is NTE55 - Do you guys agree?
          • R_J
            • 9549
            I'm sure you can run it without the one set of transistors, would be the 15 watt version. The problem with the nte is you need mounting hardware to insulate the tab (collector) I would find an alternative that had the isolated case
            UTsource has the ktb1367-y for $1.51 each, and ktd2059 for $1.67
            there are eb sellers that have them also, one even has 2 of each for $16.95
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              #26
              mje are a good replacement .. bd for drivers . eg bd139 140 ..mje15003 15004 ... top of my head thinking there so check the specs before proceeding .... these should be in stock from reputable dealers ... sack nte ..
              • fuxxy
                • 318
                FIXED!
                Thanks guys!
                Since I was fixing this for free, I just wanted to get it over with.
                I purchased a single complimentary pair of transistors from Fry's (NTE54 & NTE55), and installed them, replacing both in the pair of the side that went bad.
                Reinstalled the zeners, and the resistor, and it powers on and works now!
                • madan1
                  • Nov 2016
                  • 682
                  • Bulgaria
                  #28
                  did you check the emitter resistors? usually they fail with the transistors.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    #29
                    Good job!!!
                    • Babbar
                      by Babbar
                      04-12-2024, 01:12 AM
                    • drscoot
                      HP X360 convertible battery blown fuse error, not charging
                      by drscoot
                      HP Modelnumber: 14-dh0061nb​
                      This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                      The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                      I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                      And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                      All these 3 batteries are charging...
                      12-15-2023, 05:54 AM
                    • jesterace
                      Samsung UE46ES8000 Blown fuse but no other signs of short
                      by jesterace
                      Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                      09-11-2024, 03:14 PM
                    • whc14765
                      Gigabyte 980TI Windforce - Blown PCIE Fuse
                      by whc14765
                      Hey,
                      I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
                      The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
                      I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
                      1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
                      04-08-2022, 06:22 PM
                    • NConstantinou
                      Lenovo nm-d471 fv1 fuse blown
                      by NConstantinou
                      I found that fv1 on one side i have 19v and on the other side 0v.
                      The fuse is 3a 32v FOR BACKLIGHT.
                      I do not have such a tiny fuse.
                      Can i replace it with a wire and what size.
                      I know i am overpassing fuse but i don't have any other solution.
                      02-14-2023, 06:44 AM
