Strange noise when powering up
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Hi there.
    Recently got a second hand Yamaha RX-A1010 receiver. It was working just fine for some time, but then suddenly developed a new "feature". When powered-up from long stand-by it makes a "camera-flash-charging" noise.
    I still have not opened the hood ( there is a warranty label which I prefer to keep in case decide to sell it ).
    Find attached a wav file with the sound and the service manual.
    From the schematics of the power supply ( pg 133 ) , it looks like the noise is happening when the main power relay RY201 closes and powers up the transformer. From there ( pg 132 ) there is another relay ( ry109 ), a rectifier bridge ( d1050 ) and the big 12000uF filter capacitors ( c1105 c1106 ).
    So I guess the noise is associated to the charging of the caps? Is it the transformer or the caps?
    For now I do not see/hear any issues with the functionality of the receiver, but is it possible to get worse?
    By the way, what's the point of the RY109? Is it selecting different voltages for the amp side... something like "eco" mode?
    p.s. the manual is too big so had to upload it here -
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Re: Strange noise when powering up
    And here is the development - after some time it started to make noise even after the boot procedure. At first the noise was stopping after some time and after that all features worked fine. Then the noise started to be continuous and some of the "smart" features stopped working.
    At that time I finally opened it and after several temporary fixes ( resoldering the power board ... which at this moment I cannot explain why it even worked ) I think I finally was able to find and replace the problematic parts.
    With tapping different components I was able to find the problematic nodes - two pulse power supplies - ic943 and ic944 ( BD9329AEFJ ) on the hdmi board.
    So, I resoldered the pins of the chips, replaced the two big smd inductors and for a week the unit has been working fine.
    I also have some scope screenshots from the time when the noise was occurring and I can upload them here if anyone is interested.
    Now I'm just uploading some visual aid from before and after.
    The strangest thing was that the unit was booting up fine, no errors were recorded and the system menu was showing all Vs withing the limits.
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Thanks for sharing ..
      • tony359
        by tony359
        11-28-2023, 05:18 AM
      • courtcircuit
        Philips HTS8000 home cinema noise problem
        by courtcircuit
        Hello
        I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
        Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
        Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
        I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
        Removed each of tyhe boards
        02-08-2025, 08:22 AM
      • wolf1976
        wireless receiver for 6 speeds fan control with remote control
        by wolf1976
        hi i have a receiver that is destroyed from the overvoltage i guess
        my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
        the motor fan has not label
        i have an other receiver operational
        In your opinion can i measure the voltage at the output ?
        what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
        thanks in advance...
        07-23-2025, 03:12 PM
      • CdDvdFlash
        DSE GE6878 possible TV receiver dying remote not working well
        by CdDvdFlash
        For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
        07-03-2024, 03:55 AM
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
