SKytec smwa15-18-3
  • PCManiac
    • Sep 2012
    • 28
    • Str
    SKytec smwa15-18-3
    Hey guys,
    I got asked if I could repair this Skytec's subwoofer circuit.
    It had one of the big caps dead so it got replaced, it was blowing the fuses so i replaced the IC TDA7294V cause it had a black (burnt) leg and didn't blow anymore.. yet, the marked trace started smoking.
    Yes, the board already looked that terrible when it got to my hands..
    And I apologize for the bad soldering on the IC.. I didn't notice it was that bad till I took these pictures.. :x
    But still, any idea on why it is burning the track after I give it power?
    Does any one have any sort of schematics and parts list?
    And what's the value of that blue resistor on the front side of the board?
    Would love to replace the whole PCB as it does look like crap to me but got to figure how to draw one and where to send it to be printed first..
    Thank you for your help.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: SKytec smwa15-18-3
    Clean any carbon that may have been formed between the adjacent traces. You may have to scrape heavily. Look at the components connected to the burning trace. They may be 'leaky' and if you are doubtful replace them. the Blue resistor looks like 470 ohms.
    • PCManiac
      • Sep 2012
      • 28
      • Str
      Thanks Andrew F. Ali
      Won't scraping it remove masking?
      And any idea in why did they added solder over the traces? Am guessing cause it was getting too hot from the current..
      • chth96
        Is it possible bridging tiny broken trace
        by chth96
        When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
        cutting tiny trace.
        This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
        Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
        But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
        12-03-2022, 11:32 PM
      • stormanimal83
        Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
        by stormanimal83
        Hey....
        Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
        my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
        01-18-2024, 02:15 PM
      • MicroSMD Lab
        MSI MS-16W1 no power, EC replaced by other.
        by MicroSMD Lab
        Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
        03-27-2025, 07:35 AM
      • OOF DIO
        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
        by OOF DIO
        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
        (Had 3 problems, now just 1)
        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
        04-19-2025, 05:03 PM
      • Friend4Cap
        Tuf gaming b550-pro damage circuit trace help!
        by Friend4Cap
        If anyone can help it will be very appreciate!!
        Motherboard - (TUF GAMING B550-PRO) client connected Floppy Drive 4-Pin Power Connector to RGB_Header_1 +12V G . R . B and Burn one N6V8 and Damage all circuit trace, please check pictures, Motherboard not turning on & everything check ok, no short to ground, I need to repair all circuit trace and replace burn N6V8 but don't know where this 5 circuit trace connect to N6V8. If anyone with TUF GAMING B550-PRO can check. “Thank you in advance”...
        05-07-2023, 05:38 PM
