Radio mercedes benz ra4210 dump
  • jougounou
    • Jul 2014
    • 185
    • niger
    need to unlock myradio mercedes benz ra4210 dump pls
    sn/al421020546939
  • petehall347
    • Jan 2015
    • 4426
    Re: Radio mercedes benz ra4210 dump
    you can unlock it with unlock code generated from number on unit .. i have some generators somewhere on a pc . if i find i will post back .
    • jougounou
      • Jul 2014
      • 185
      • niger
      Thanks petehall347 i will be very happy if u do so
      • petehall347
        • Jan 2015
        • 4426
        just found this but not sure if it covers yours .. if not i see sites that can do it for not much money ..
        it says apk so mobile phone software ..http://www.radiocodescalculator.com/
        it could take me a long time to find the generators i have as might only be on a hard drive that i have lots of them .. be easier to download again ..
        just search on the net ..
        • petehall347
          • Jan 2015
          • 4426
          this is supposed to be free ... http://www.radio-code.lt/
          • jougounou
            • Jul 2014
            • 185
            • niger
            Ok gimme the name of the generator for me to search on the internet pls
            • petehall347
              • Jan 2015
              • 4426
              look above .. i found on a website that people say it works fine .
              • jougounou
                • Jul 2014
                • 185
                • niger
                thanks a lot
                • petehall347
                  • Jan 2015
                  • 4426
                  did it work for you ?
                  • jougounou
                    • Jul 2014
                    • 185
                    • niger
                    worked thanks
                    • shelby5041
                      clock radio / radio lifespan?
                      by shelby5041
                      hi
                      ive got a modern digital clock radio approx 15yrs old
                      my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                      since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                      the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                      it uses very little power just a few watts i would imagine that may have something...
                      09-14-2024, 03:30 AM
                    • jovani1989
                      HikVision DS-7104HQHI-K1 MB: DS-80303_P REV 2.0 Firmware dump or unlock required
                      by jovani1989
                      HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!...
                      06-11-2025, 01:54 PM
                    • FALKLAN
                      Mercedes-Benz W163 Bose Audio System
                      by FALKLAN
                      Howdy everyone!
                      I have a SUV with a Bose audio system and I'm considering either a system upgrade, or purchasing a complete replacement system while bypassing the integrated Bose system.
                      On the Bose side, I have not found any specifications yet. It's a decent system but I'm, at a minimum, replacing all the factory speakers, head unit and adding an amp and two 8" subs. The Bose is a 2ohm system and I'm not certain about this point. In order to use a 4ohm set of speakers (component/loud), I would need to install 2 sets of 4ohm speakers wired in parallel to match the...
                      12-07-2023, 11:22 PM
                    • UserXP
                      Vintage SONY Digital Clock Radio ICF-C12W no audio
                      by UserXP
                      Dear all,
                      I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                      i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                      My question is, do you know of this brand of capacitors and how bad are...
                      07-21-2025, 08:35 AM
                    • praveenramavath
                      Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                      by praveenramavath
                      Hello All,
                      I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                      https://www.hifivision.com/threads/m...-screen.98243/
                      Troubleshooting Summary: Majority Internet Radio - Flash Chip
                      04-26-2025, 09:08 AM
