M-Audio EX-66 Active Speaker -
  • rattenfänger
    • Feb 2017
    Hello.
    Glad I found this forum since I really got started in electronics lately and from time to time I'm really kind of in dead end when it comes to troubleshooting a problem. So thanks in advance for every help.
    I have Problem with my Pair of M-Audio EX-66 speakers.
    I found a thread on this forum about these speakers that I will link here. I decided to start a new one because my Problem slightly differs and I wanted to keep it "clean" (https://www.badcaps.net/forum/showthread.php?t=33215)
    One of speakers just works fine. The other one has some kind of noise/hum. Its not very loud but still annoying. if you decrease the volume with the potentiometer on the back of the device, the hum gets louder. The more you approximate 0db the quieter it gets and nearly disappears.turning up the volume even more the general hiss gets too loud to really hear any hum. So I'm not sure if it may increase again.
    The other thing is that the lower the volume is set on both speakers the more the actual volume you hear will differ between them. With the potentiometer set to "0db" there is no difference. on "-40db" I increase the volume of the corresponding input signal from my PC about 10 db so they both match again.
    So what i have done so far. i swapped boards to see if the woofers were damaged but the problem swapped with the board.
    I checked for obviously bad caps but couldn't find anything. I cleaned of all the glue. There was a space on the board where it completely covered a big 100ohm resistor (unlike the board of the working speaker) that connected one pin of the potentiometer to the chassis. The glue got very solid there. It was cracked and inelastic.
    Since I don't have access to an oscilloscope at the moment. I was wondering what else I can do. Any suggestions what to check or what the problem i described could be?
    If you need further information, pictures or a sound sample of the hum please let me know.
    Thank you very much for all your help!
  • jasonbay13
    • Jul 2014
    • 185
    • usa
    Re: M-Audio EX-66 Active Speaker -
    yeah, i've come across some speakers that the glue had caused hum and crackling. but it seems you've cleared it.
    capacitors can be leaky or have a high esr without looking bad.
    is it 60hz hum from mains? maybe replace the main filter caps and any nearby the volume pot?
    does the low cutoff make any difference? that should help narrow it down a little. do also make sure there are no bad solder joints, such as: https://www.youtube.com/watch?v=fdfj7_czRcs
    • RetroComputingGrotto
      Behringer MS16 Speakers - Low Volume on One Speaker
      by RetroComputingGrotto
      I've had a set of speakers come in with the fault of not powering on.
      I could hear something wrattling around in the speakers so we played a game called Guess What's In The Speakers! and this is what we found:
      1 random loose nut and part of a BIC Biro pen.
      After removing these foreign objects I plugged in the speaker and powered it on and found the volume to be quite low. On plugging in the other speaker it was very loud, but only out of the other speaker, this side was still very low.
      05-20-2024, 07:29 AM
    • Xenon-Codex
      Volume potentiometer loudness tap bypass?
      by Xenon-Codex
      I salvaged a Sony TA-F170 with broken volume potentiometer. It has a special pot with a loudness tap in the middle, of course not available anymore.
      Is the loudness somehow possible to get to work, at least constant instead of variable? I have a regular potentiometer which works, but the loudness does not.​
      01-16-2024, 01:53 PM
    • falkikowski
      NuPro A-20 Active Speaker burnt LNK 606
      by falkikowski
      The LNK 606 on the power board for my active speaker just went to hell.
      I would like to replace it, but this very model is hard for me to get. Can I replace the LNK 606 with the LNK 616 or the TYN 266?
      I also attached a picture of the back side. The burnt part above R2 is a bridge, that is connected to the COM of two chunky electrolytic condensator (82 micro Farad, 400 V). I just tidied that up. Or should I worry about that?
      Thanks​
      falkikowski...
      10-03-2024, 03:09 AM
    • karthur
      Vizio D65x-G4 Volume changes on its own
      by karthur
      On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
      It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
      06-05-2025, 08:13 AM
      HP ProDesk 600 G5 + Bluetooth Speaker 400 ProDesk 600 i7-9700 Specification for Upgrade or Repair
      This specification for the HP ProDesk 600 G5 + Bluetooth Speaker 400 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Bluetooth Speaker 400 boardview and ProDesk 600 G5 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
      09-12-2024, 02:30 PM
