Now THESE are some caps...
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Got a new amp for my system. It's an Adcom GFA-545. Conservatively rated at 100wpc x 2.
    The top component is the amp, of course
    Ludicrous gibs!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Now THESE are some caps...
    Manufacturer of the caps is Towa? Fujitsu Towa, I believe http://www.faradnet.com/company/c0001241.htm
    Ludicrous gibs!
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      those are tiny.wait till you see the ones i work with on motor drives.
      each the size of 3 pound coffee cans and in banks containing up to 100 of them.
      • Wizard
        • Mar 2008
        • 2296
        Crimped eyelets on solid gauge wires is big no no! Mechanical failure soon comes up because solid wires does not conform to the crimp readily. They are designed for stranded wires only.
        Best design is busbars and screws for capacitors, can be rebuilt to this configuration.
        By the way, note the star grounding system. That's excellent.
        Cheers, Wizard
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          wonder if the mfr was smart enough to solder the crimps too.
          • Krankshaft
            • Jan 2007
            • 2328
            Is there any real reason why manufacturers use torroid transformers on amps?
            Do they have better characteristics than iron core transformers?
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              Pics or ban!!
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Originally posted by Topcat
                Pics or ban!!
                i will take some pics next time i am onsite there.
                next time will be the first severe thunderstorm outbreak of spring.
                they get nailed several times a year.
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  As far as I know, they just tend to be quieter, and higher output than iron core.
                  From Wiki, I found this - The magnetic flux in a toroid is largely confined to the core, preventing its energy from being absorbed by nearby objects, making toroidal cores essentially self-shielding.
                  Ludicrous gibs!
                  • Logistics
                    • Apr 2007
                    • 721
                    Insane! How many microfarads are those each? I read on a site that a typical rule-of-thumb for stiffening vs. wattage is .5F per 500W, which is the same as 1000uF per 1W, correct?
                    This article explains why, at least the author feels, they are better: http://www.tnt-audio.com/clinica/ssps1_e.html
                    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Hehe yea, those are awsome kc8adu
                      A local sawmill company uses such caps to increase their PFC factor
                      If it falls below a certain value they get a hefty price increase
                      They got replaced pretty got damn quickly when one of their power bills was suddenly $5000 higher than it usually is!
                      Turns out the bank had failed, nice of the power company not to inform them too!
                      • glen65
                        • Dec 2008
                        • 30
                        So are these
                        • Wizard
                          • Mar 2008
                          • 2296
                          Now we are talking about THOSE. This was commonly found in vintage computers that filled racks as well. And there were some in early 70's computer boxens.
                          Cheers, Wizard
                            by momaka
                            03-12-2025, 03:42 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
