soundcraft spirit m4 mixer troubleshooting
  • petehall347
    • Jan 2015
    • 4448
    #41
    Re: soundcraft spirit m4 mixer troubleshooting
    see if you can find the stain where the water got in ..it might be a clue
    • 5inc
      • 120
      • Spain
      #42
      hi there I'm back,
      It's too late to look for a stain, I've had it for so long sitting on the shelf, when I picked it up again I gave it a little brush. That was before knowing it got wet. But it was a good idea, thanks, I'm taking a note for the future.
      Now, I had the signal tracer that was linked at the beginning, but I had to make a new one with a little potentiometer because the only battery amp I have right now is one of those eggy mp3 speakers, with no volume control and only one miniUSB input. Done.
      So now i'm starting to test it, and for a first check I tried eq's and gain pots. And it sounds! ^^
      Following the scheme I managed to find a couple of bad resistors for now, but I don't think that's the major trouble... I'll grab a cup of strong tea and get on it.
      • petehall347
        • Jan 2015
        • 4448
        #43
        well done keep searching ..
        • 5inc
          • 120
          • Spain
          #44
          hey, I took those resistors, but out of circuit they seem ok.. they are r592, r593 and their couples at the "P/B replaces mix"(master A page)
          I also got a weird resistance reading at the resistors after the pan pots at mono at mono channels (i'm sticking to those for now), but just like the ones before mentioned, I believe the circuit is fooling me, since they all have the same readings...
          Signal vanishes around the Opamps, they have power, but not much sound after r457(mono input cannel 1).. dunno if it is because of it's value or what.. tomorrow I'l tackle it again.
          • Khron
            • Sep 2006
            • 1350
            • Finland
            #45
            Sounds like progress
            I recall 3-4 years ago, buying a Soundcraft FX16-II that had gotten something spilled on it (i might be wrong, but i do recall i bought it as faulty). Actually yeah it did, i'm starting to remember having to "patch up" some power traces going to opamps, that had been corroded by whatever it had "drank". I might've had to replace an opamp or two as well, but it's been a long time
            Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
            • 5inc
              • 120
              • Spain
              #46
              yes, it is. I am blissfull.
              It's like a new dimension opening before my eyes! Now I got to a point where the signal goes bad, and further on I just can't keep tracking.
              Is it the time to build a cable for signal injection? Is it as simple as picking up a jack and shoving a blocking cap and some resistors in between like the tracer?
              • Khron
                • Sep 2006
                • 1350
                • Finland
                #47
                For signal injection, (in)to where? Right after the point the signal gets lost, or..?
                • petehall347
                  • Jan 2015
                  • 4448
                  #48
                  just a blocking cap should do it .
                  you really need to have control over the level . something with a vol control .
                  • 5inc
                    • 120
                    • Spain
                    #49
                    Yes khron,
                    to inject just past the bad point, so I can look for further trouble while I wait for the pieces to arrive... do you think that's a bad idea?
                    I allready put a little pot at the tracer, i'l just do the same on the injecter...
                    • 5inc
                      • 120
                      • Spain
                      #50
                      btw, the cap goes in series through right/left or through the negative lead?
                      or doesn't it mind?
                      • petehall347
                        • Jan 2015
                        • 4448
                        #51
                        cap on probe . negative/ground to chassis or ground point if floating ground
                        • 5inc
                          • 120
                          • Spain
                          #52
                          Sssugar, i just did it the wrong way around.
                          I got a cut minijack lead that was chopped off, and connected the negative ground of it to the cap and the pot, and that was going to be neg/gnd, then the other 2 wires were going to be the probe.
                          If I wanted to have 2 probes, should I have a cap on each? would it be possible just like that, to test both L&R at the same time? I'll stick to one for now, just asking
                          thanks!
                          • petehall347
                            • Jan 2015
                            • 4448
                            #53
                            the idea of the cap is to block dc current going one way or the other .
                            • 5inc
                              • 120
                              • Spain
                              #54
                              Does that mean it doesn't matter the side?
                              • petehall347
                                • Jan 2015
                                • 4448
                                #55
                                just put a cap on the signal side . ground to ground .
                                • 5inc
                                  • 120
                                  • Spain
                                  #56
                                  Ok done, but it ain't doin much... i'm using the tracker to test it out, but it barely sounds, tried sliding the pots up&down and it's still pretty low, shall i try with an other cap? the one I put in is a 1uf.. maybe too much?
                                  • 5inc
                                    • 120
                                    • Spain
                                    #57
                                    wait, showing it to a flatmate it seems to work now, I don't know what happened, maybe it was a bad contact, I'm starting to have too many wires on my desk.
                                    that said, next is plugging it in to see.
                                    • 5inc
                                      • 120
                                      • Spain
                                      #58
                                      well well,
                                      Reading johnnydiaz's "How to check an OP AMP in circuit" thread, he checked for voltage at pin 8 he got 15.60vdc & pin 4 -15.35vdc
                                      I instead have 10.4vdc on 8, and 0.7vdc on 4....
                                      • Khron
                                        • Sep 2006
                                        • 1350
                                        • Finland
                                        #59
                                        Is that the case on the opamp where the signal "ends"? And do you get the same measurement on the other opamps nearby?
                                        • petehall347
                                          • Jan 2015
                                          • 4448
                                          #60
                                          what op amps are you checking ?
                                          • jason123
                                            Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                                            by jason123
                                            Hi there,
                                            I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                                            So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                                            I see 2 posts that are relevant:
                                            https://www.badcaps.net/forum/troubl...j-oled-5-blink
                                            https://www.badcaps.net/forum/troubl...g-hardware-dev...
                                            10-29-2025, 02:01 PM
                                          • Longon
                                            Behringer Pro Mixer DJX-750
                                            by Longon
                                            Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                            08-11-2025, 02:17 PM
                                          • BigOof
                                            Marantz SR5007 popping on volume change and mute in Direct Mode
                                            by BigOof
                                            I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                            12-12-2024, 06:15 AM
                                          • Bektronics
                                            Schematic Digital Audio mixer RCF type M18
                                            by Bektronics
                                            Hello dear audio friends.
                                            I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                            The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                            I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                            Thanks in advance if anyone can help me with this schematic.
                                            Of course, all information about this digital mixer and possibly references...
                                            07-24-2023, 06:40 AM
                                          • blues_spirit
                                            practical courses for troubleshooting pc motherboards
                                            by blues_spirit
                                            Hello from France,
                                            mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
                                            Do you think this is feasible for me? I...
                                            12-18-2022, 12:56 PM
